Question about HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop
Xw 4600 917-front audio not conntect - HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop
  • HP Master
  • 2,251 Answers
Old post , error 917, sure, all do that when....
P23 wired cable fell off(or loose, its keyed)
or wrong panel used, (hp makes many , only 1 works here)
the offical, service manual covers all POST errors
and is still free, to see at real HP at any time.
Hit F1 and PC will boot ok, even with that error.
see p23 here.... front_audio jack, bottom left mobo.
http://www.pcdied.com/intel-magic/xw4600.html
Posted on Oct 16, 2017
My polaroid tablet is conntected to the wifi but says failer to conntect to server
Did you verify the wireless is enabled and connected to your network?
A lot of tablets will auto-disable the wireless when they go to sleep.
Dec 29, 2012 | Polaroid 7 in. Internet Tablet
Looking for a 2.2 ecotec timing chain diagram with pictures
Getting the timing chain back on these engines can be tricky and requires more than just a diagram to get right. Here is how the timing chain should be reinstalled. Keep in mind that this engine can cause damage to the valves if the timing chain has any problems while the engine is running so it may not be a bad idea to setup the timing system as follows and do a compression test to make sure that everything is in order there.
Install the crankshaft sprocket with timing mark at the 5 o'clock position. Lower the timing chain through the opening in the top of the cylinder head. Carefully ensure that the chain goes around both sides of the cylinder block bosses (See 1 & 2 in picture): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412535.gif
Install the intake camshaft sprocket with the INT diamond at the 2 o'clock position. Hand tighten a NEW intake camshaft sprocket bolt. Route the timing chain around the crankshaft sprocket with the matching colored link aligning with the timing mark. Route the timing chain around the intake camshaft sprocket with the uniquely colored link (1) aligning with the INT diamond: http://gsi.xw.gm.com/image_en_us/gif/000/000/466/466558.gif
Install the timing chain tensioner guide through the opening in the top of the cylinder head. Tighten the timing chain tensioner guide bolt to 10 N·m (89 lb in): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412160.gif
Install the exhaust camshaft sprocket with the timing chain matching colored link (3) at EXH triangle aligned at the 10 o'clock position: http://gsi.xw.gm.com/image_en_us/gif/000/000/466/466570.gif
Ensure the timing marks and the colored links (1,2,3) are correctly aligned: http://gsi.xw.gm.com/image_en_us/gif/000/002/003/2003412.gif
Use a 24 mm wrench to rotate the camshaft slightly, until exhaust sprocket aligns with the camshaft. Hand tighten the NEW exhaust camshaft sprocket bolt: http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412536.gif
Install the fixed timing chain guide. Tighten the fixed timing chain bolts to 10 N·m (89 lb in): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412165.gif
Apply sealant, GM P/N 12378521 (Canadian P/N 88901148) compound to thread and install the timing chain guide bolt access hole plug. Tighten the chain guide plug to 90 N·m (66 lb ft): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412164.gif
Install the timing chain upper guide. Tighten the timing chain upper guide bolts to 10 N·m (89 lb in): http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412167.gif
Inspect the timing chain tensioner. If the timing chain tensioner, O-ring seal, or washer is damaged, replace the timing chain tensioner. Measure the timing chain tensioner assembly from end to end. A new tensioner should be supplied in the fully compressed non-active state. A tensioner in the compressed state will measure 72 mm (2.83 in) (a) from end to end. A tensioner in the active state will measure 85 mm (3.35 in) (a) from end to end.
****If the timing chain tensioner is not in the compressed state, perform the following steps. Remove the piston assembly from the body of the timing chain tensioner by pulling it out. Set the J 45027-2 (2) into a vise. Install the notch end of the piston assembly into the J 45027-2 (2). Using the J 45027-1 (1), turn the ratchet cylinder into the piston: http://gsi.xw.gm.com/image_en_us/gif/000/000/797/797246.gif
Inspect the bore of the tensioner body for dirt, debris, and damage. If any damage appears, replace the tensioner. Clean dirt or debris out with a lint free cloth. Install the compressed piston assembly back into the timing chain tensioner body until it stops at the bottom of the bore. Do not compress the piston assembly against the bottom of the bore. If the piston assembly is compressed against the bottom of the bore, it will activate the tensioner, which will then need to be reset again. At this point the tensioner should measure approximately 72 mm (2.83 in) (a) from end to end. If the tensioner does not read 72 mm (2.83 in) (a) from end to end repeat the steps required to return it to it's compressed state above.
Install the timing chain tensioner. Tighten the timing chain tensioner to 75 N·m (55 lb ft). Use a suitable tool with a rubber tip on the end. Feed the tool down through the camshaft drive chant to rest on the timing chain. Then give a sharp jolt diagonally downwards to release the tensioner: http://gsi.xw.gm.com/image_en_us/gif/000/000/412/412158.gif
Use a 24 mm wrench to hold the camshaft. Tighten the NEW camshaft bolts to 85 N·m (63 lb ft) plus 30 degrees: http://gsi.xw.gm.com/image_en_us/gif/000/000/630/630311.gif
May 25, 2011 | 2002 Pontiac Grand Am
Need cords
It should have the following connections:
Analog audio out;
Optical digital audio out
Composite-video out
Headphone jack
If you want to conntect the player to a tv use a RCA cable and connect it to the input on the TV
Mar 08, 2011 | Mintek MDP-5860 Portable DVD Player
SmartTech Webcam XW-9014 software
First u need to go manufacturer site for download your driver with the help of your webcam model or go to driverguide.com
Thanks For Helping U...
Aug 29, 2009 | Logitech Quickcam Chat Webcam
Change headlight
hello. below is the procedure for removal of the headlamp for bulb replacement. to access the headlamp you will need to remove the bumper fascia. http://gsi.xw.gm.com/image_en_us/gif/000/001/725/1725371.gif Callout Component Name 1 Front Compartment Sight Shield Plastic Retainers (Qty: 6) 2 Front Compartment Sight Shields (Qty: 3) Tip Each front compartment sight shield is serviced separately as needed for repairs http://gsi.xw.gm.com/image_en_us/gif/000/001/728/1728611.gif Callout Component Name Preliminary Procedure Remove the front wheelhouse liner. Refer to Front Wheelhouse Liner Replacement . 1 Front Fascia Extension Plastic Retainers (Qty: 5) 2 Front Fascia Extension http://gsi.xw.gm.com/image_en_us/gif/000/001/733/1733942.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedures Remove the front compartment sight shields. Remove both front bumper fascia extensions. 1 Front Bumper Fascia Reinforcement Nut (Qty: 2) Tighten 6 N·m (53 lb in) 2 Front Bumper Fascia http://gsi.xw.gm.com/image_en_us/gif/000/001/736/1736893.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedure Remove the front bumper fascia. 1 Headlamp Nut (Qty: 1) Tighten 6 N·m (53 lb in) 2 Headlamp Bolts (Qty: 3) Tighten 6 N·m (53 lb in) 3 Headlamp Assembly
Jun 13, 2009 | 2003 Cadillac CTS
Driver for pc camera brand :x5tech model.xw-354 rosacold@yahoo.fr
hello friend u
how r u
this webcam Driver give mi model ;xw-354
send mi my e-mail usaa_ali19@yahoo.cam
May 18, 2008 | Cameras
HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
