Question about Pool & Spa
Replace a hotsprings rotary adjustable jet - Pool & Spa
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Unscrew it should come out
Posted on Aug 25, 2014
Hotsprings spa controller error codes
Here is a link to their owners manual. Any error codes you need should be in the manual.
http://www.hotspring.com/owners/owners-manuals
Apr 15, 2013 | Pool & Spa
How do you get to the throttle jets huskvarna 130BT blower
The 130 has a rotary style carb, so the only adjustment is down through the top of the throttle spindle, you will need a very small flat blade screw driver, the screw down here will lift or raise the needle in the carb, there may well be a plastic plug to remove before you can get deep enough to adjust it.
Dec 27, 2012 | Husqvarna 295cc Back Pack Blower HVH 130BT
Hotsprings spa will not heat after draining and filling. power is on and jets work.
you may not be getting enough power to support all of them at once
Mar 07, 2012 | Pool & Spa
ECHO PB-250 blower new used one time carb.needs adj.can this carb.be adjusted
Your machine has a rotary-valve diaphragm type carburetor. These carburetors typically only have an adjustment for the IDLE speed with an available option to control the main jet with an adjustable mixture needle.
http://www.echo-usa.com/Products/Blowers/PB-250
Here is the info on the Zama rotary-valve diaphragm carburetor.
http://www.zamacarb.com/prodlist.html#RB
Some have a small adjustment needle in the center pivot of the rotory part, under a brass plug...but most have nothing. Many end users and techs are complaining about the non-adjustable carbs. They are made this way to meet the more stringent EPA emissions codes that are getting tougher each year.
Jul 03, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
How do u set the clock on the alpine cdm 9803 cd player
Here is the manual.
http://cartoys.com/cartoy/pdfs/cdm9801_manual.pdf
1 In the Clock priority mode, press and hold the
DISP button for at least 3 seconds while the
time is displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours
while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder.
4 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking. The time is
automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder.
Feb 14, 2011 | Alpine CDM-9803 CD Player
How do we set the clock
1 In the Clock priority mode, press and hold the DISP/
TITLE
button for at least 3 seconds while the time is
2 Turn the Rotary encoder to adjust the hours while the
3 When the hour has been adjusted, press the Rotary
encoder
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
can also be manually set by pressing the Rotary
encoder
May 16, 2010 | Alpine CDA-9825 CD Player
How do you change the time on my radio?
Rotary encoder.
May 10, 2010 | Alpine CDM-9821 CD Player
I have a Hotsprings Grandee tub. I drained and
Probably a ground Id check that water did not get into any ele.system
Apr 16, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Jet adjustment where are are jet adjust screws?
There is no way to adjust the jets on these carbs, fuel metering is done by a fixed sized main jet. If you need to adjust you must replace the jets with either a larger or smaller size jet.
Dec 30, 2009 | 1985 kawasaki ZL 900 A1 Eliminator
Rotary jets not spinning
Hi there........Rotary jets not sinning can be caused by....(a) something impeding their rotation..dishwasher air freshner hanging in incorrect place...(b).incorrect position of upper tray resulting in large plates impeding spray arm rotation...(c).cuttlery basket incorrectly placed or loaded with cuttlery impeding spray arm...(d) wash pump blocked or damaged impeller resulting in insufficient pressure to spray arms...
regards Sir Galahad
Aug 12, 2009 | Dishwashers
Pool & Spa Logo
88 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
