Question about Digihome LCD TV
Sound dropping out on Digihome LCD TV - Digihome LCD TV
Brand new tv and when I switched it on there is a huge black area shaped like a hill coming from the bottom half way up my screen - no sound
return for replacement or repair if try to repair or tinker with will void any warranty or return policy
Aug 15, 2016 | Digihome LCD TV
Can u get surround sound to play on Normal TV channels it's digihome 50" led smart TV
Sure are you using a preamp component system or do you want to play it on the tv if you do have a pre amp run the RCA cables to sterio input on amp or aux then in the setting of the amp go into sound and put the aux to 6.1 also remember that to use audio out on your tv
May 26, 2014 | Digihome LCD TV
DVD player on my digihome TV is not working
Go to digihome support to get the Manuel
Apr 16, 2014 | Digihome LCD TV
The sound on my Digihome TV keeps going off and only returns by switching the set off then back on again. Any solution ideas please
Digihome is not a brand unto itself. It is manufactured by a Foreign Country (I believe it's in Turkey) by the name of Tesco. Very large territories for sales in Europe of the Digihome label and a half dozen others. You will probably have to find a TV shop that will look at it for you as they have no service nor even their own. website.
Oct 28, 2013 | Digihome LCD TV
The sound keeps going off on my digihome lcd tv
will it come back on if you wrap it on the side? Probably a bad solder connection on the circuit board
Jul 21, 2013 | Digihome LCD TV
Sound distortion on lcd tv
If you mean by this that their is an occassional echo, then this is a frequent problem with digital reception and not a fault with your TV. This is a wide spread problem that doesn't appear to have a solution
Feb 15, 2013 | Digihome LCD TV
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
Oct 16, 2012 | Digihome LCD TV
Digihome dvd not working
If it's a burned DVD or a CD, it might just be incompatible. Not every disc will work in the kind of older drives Digihome uses.
Aug 29, 2012 | Digihome LCD TV
Digihome 32845 lcd user manual
I need an instruction manual for a Digihome 32845 lcd tv
Jul 23, 2012 | Televison & Video
Digihome LCD TV Logo
11 people viewed this question
Top Digihome Televison & Video Experts
john h
D. E. Hev
Are you a Digihome Televison and Video Expert? Answer questions, earn points and help others
