Question about Dell IN1910N 19" Monitor
How do you remove the stand from the monitor?
I removed the screws from the rear but the stand won't come off.
3 Suggested Answers
  • 749 Answers
SOURCE: Remove stand
we need picture of it, if your not talking about the swivel base.
Posted on Dec 05, 2007
onlybrosh
  • 284 Answers
SOURCE: How do you Remove the Stand for a Dell 1706FPVT
http://support.dell.com/support/edocs/monitors/1706fpsf/EN/appendx.htm
give them a call
Posted on Mar 03, 2011
Service manual repair
Remove first monitor from the stand then the rear panel cover may be removed by removing screws from the bottom then sliding out the rear cover from the front panel.
Dec 28, 2013 | ASUS VB195T 19 inch Monitor
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
I have a olevia237 t12 lcd tv i cant seem to ge the stand off of? any tips?
Is it the stand you're trying to to take off? If so, follow the steps below.
1 Unplug the television and remove any connected audio or video cables from the rear.
2 Place the television face down on a soft bed spread to avoid screen damage.
3 Examine the rear of the television and locate the screws securing the stand to the monitor. Depending upon your particular model, the screws securing the stand to the television may be marked with an "Arrow" symbol.
4 Remove the screws securing the stand to the television with an appropriately-sized Philips screwdriver. Slide the plastic stand off the rear of the television.
5 Store the mounting screws and plastic stand for future use.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Aug 20, 2011 | Olevia 237T 37 in. LCD TV
I can't open my samsung t220 housing
1) Pull the stand out of the bottom of the monitor (it isn't held in with any screws).
2) Remove the two screws now revealed by the removal of the stand. These are the only two screws holding the rear panel on.
3) Slide a couple of old credit cards into the gap between the front and back panels starting from where the base inserts. As you lever the two panels apart, slide the credit cards along the gap to stop them from clipping back together.
4) Insert a flat-head screwdriver into each of the little slots at the bottom of the monitor and start to lever the back panel away from the front bezel.
5) Carefully use the screwdriver to prise the back panel away from the monitor, starting from the gap you created using the first two slots and working your way gradually around the frame. There are tiny clips every three inches or so all the way around. Each one will release with a fairly loud 'pop', but don't be too concerned - if you're careful, you won't do any damage (use just enough force to get it to release, without using so much you smash anything).
The plastic IS fairly soft, so do your best not to damage it - using credit cards between the screwdriver and monitor will help to protect it; but then if you're doing this, I doubt your monitor is under warranty (and you won't see the small scratches and indentations you make anyway, as they're on the back of the monitor).
Feb 25, 2011 | Samsung T220HD LCD Monitor
How to remove stand from iiyama E2607WDS monitor
One can only remove the plastic neck of the stand by removing not only its four visible screws, but also the two screws at the invisible inside of the neck. To get to these, you have to remove the neck together with its metal foot. To do so, you should remove the 4 [four!!] bolts/screws that fix the metal bracket to the frame of the monitor, and then loosen the two screws at the outer left and right of the plastic back of the monitor [to get some room to move], and then slide the metal foot down and out. After removing the neck [and if you wish: also the metal] you should reposition all 4 four!] of its bolts/screws, since these are needed to keep the front and back of the monitor together. Also thighten the 2 screws at the outer left and right.
Dec 21, 2009 | iiyama Computers & Internet
How to remove stand from a samsung syncmaster 910mp
It's usually 2 screw at the base of the TV, at the rear. Loosen or remove the screws and the base should slip right off
Sep 01, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Acer Monitor Stand removal
On the rear of the monitor stand, just 1/2" above the word "Acer", is a rectangular button. push it in and pull the stand off . If you need to remove the rectangular tube, there are two snap on covers, one on each side of the tube. Pop them off and remove the screws underneath. That's it.
Feb 22, 2009 | Acer X193W LCD Monitor
Removing the mounting stand
You've probably worked it out by now, but I thought I'd post the answer anyway, for anybody who may come looking in the future......
If you look at the back of the monitor you'll see two screws which can be easily removed. What's not as obvious is the THIRD screw. To get at it you need to remove the top plastic section of the stand; I carefully inserted a blade screwdriver in the groove, then gently twisted it in a few places. There's no need to dismantle the rest of the base.
It was my 12 year-old son's eagle eyes which spotted that third screw. My contribution to this part of his MAME project was figuring out how to get at it.
I hope that helps someone.
Colin
May 12, 2008 | HP L1706 17" LCD Monitor
Opening the monitor
These are a snap to open.
Put a towel on a flat surface like the dining table.
Remove the 2 screws that hold the stand in and slide the stand out of the hole.
Remove the screw in each of the 2 bottom corners.
Remove the screw in the middle at the bottom (it was under the stand to begin with but some do not have it for some reason.)
Now comes the easy part.
Put a few fingers onto the section the power plug goes into.
Tuck your thumbs into the hole left by the stand.
Push into the power plug section downwards with your fingers at the same time pull upwards with your thumbs. The rear panel should pop up. Gently pop it all around the edges.
Hope that helps =)
Apr 10, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
How to open up the casing on this monitor.
It is not initially obvious how to access this insides of the monitor Unusually, access is only available through the front of the screen. The stand cannot be removed on this model. You need to pry a screw driver (or two) through the four holes located at the rear base of the monitor and remove the front panel surround. The LCD panel and all electronics can be lifted out after removing four screws.
Oct 03, 2006 | Tatung CLT-L50 15" Flat Panel LCD Monitor
Dell IN1910N 19" Monitor Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
