Question about Garden
Throttle cable for apache tiller
Euro1 35 classic
Walbro carburetor diagrams
must be a small tiller to have a walbro carb on it most of these have a hole drilled in throttle cam ("D" looking thing on top) that the cable has a "L " hook that goes into it cable clamp must me loosed to allow a 45 degree entry of "L" hook into "D" plate
Jul 23, 2014 | Craftsman Garden
Tiller runs at full throddle and tines continue to turn. Unable to lower throddle. What do I do?
Sounds like the throttle cable is sticking or the carburetor butterfly is sticking.
Squirt some WD-40 into the cable that attaches to the throttle handle and onto the mechanism the cable hooks to at the carburetor. Carefully actuate the throttle and see if the mechanism is moving smoothly. It may need several squirts and some actuation before it become free.
Jun 08, 2014 | Mantis 2-Cycle Tiller
Throttle linkage diagram
maybe someone took off the linkage cable what you need here is
to find a schematic of your unit and that should tell you where everything goes on the unit .you should be able to download a
schematic from the web!
Nov 09, 2013 | Garden
Troubleshooting misfire in TVS apache rtr 160 fi
Alpeshkumar,there is no problem when apache misfires it goes the same with all apaches
Nov 29, 2012 | 2011 TVS Apache RTR 160
The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
SEARS 5.5 HORSE POWER BRIGGS&STRATTON ENGINENE NEED THROTTLE CABLE PART NO 9215R
please mention sears craftsman 5.5 HP model numbers.
is the part no. 9215R correct?
Jul 14, 2011 | Craftsman Throttle Cable Murray 319306...
My Mantis Tiller 4cycle engine starts well but when I press the throttle completedly, the tines turn very slowly. This is a brand new tiller, used only twice. The engine is sitting all the way down on the...
I had same issue with my 2 year old 4cycle. Check if the carb is moving full stroke with throttle movement. I had almost no movement at carb at full throttle, found the trigger in throttle handle was cracked and bent rather than pull cable. I called mantis and they promptly sent a new handle bar ***'y with new cable, throttle ***'y Etc and that solved my problem.
BTW: If you cannot wait, I did figure out that if I pushed the carb to open with the throttle trigger fully pulled it would run at high, but when you let go.....LOL
Rich in Wethersfield, Ct
May 10, 2009 | Mantis 4-Cycle Tiller
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
