Question about John Deere Garden
JD 6200 pto stops when hot
Pto operats fine for about two hours, then stops/ will start back and run for a few minutes/ stops again. leave overnight and it will go for 2 hours again
  • 3 Answers
SOURCE: Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Posted on Dec 31, 2008
SOURCE: the engine run rough and backfires when deck is lowered with pto
It sounds like your blades may be restricted when you lower them. A possible solution for this problem would be to remove the mower deck and clean out all the dead grass buildup inside the housing.
Posted on Jun 13, 2009
wadembly
  • 475 Answers
SOURCE: Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Posted on Jun 28, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
Troy-Bilt Colt XP. Start engine and begin mowing and everything is fine. After a few swipes on the yard, 2-3 minutes, PTO shuts off. turn off and back on works shortly. PTO clutch getting hot???
electric pto clutches get HOT (not warm) for only a few reasons
(1) worn out friction disks inside
(2) foreign object(s) not allowing clutch to fully engage a good blast of high pressure air knocks out most stuff , if let go to long this leads to 1st reason
Jun 29, 2015 | Garden
I was mowing and the blades stopped turning. I disengaged and re-engaged the blades a few times and they started back. Then a few minutes later the blades stopped again then the motor stopped and will...
I have no idea what type or model of mower you have but if I was to guess I would say it has an electric pto clutch on it, if so remove your pto belt and clutch. I would bet it is burned out and locked up preventing your motor from turning over. Once the clutch is removed I will bet it will start and run fine. This is not a cheap fix but relatively easy one. Hope this helps.
Aug 21, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
I have a cub 5252 tractor/mower. I run the pto and mow for about 30-45 minutes and the blades stop as gauges go to off position while engine keeps running. The gauges come back up, but pto will not come...
This is a sign that the back of the console is getting too hot. There have been cases that the console has melted and it costs several hundred dollars to replace.
Jun 13, 2014 | Garden
Pto clutch electrical
1. Check battery (specific gravity and load test). 2. Check voltage going into battery while running without and with pto engaged. 3. Make sure unit is running at full throttle whenever electronic PTO is engaged otherwise it wont keep battery charged up.
Feb 24, 2014 | Garden
2006 Honda Element engine sputter
Temp.gauge really has nothing to do with the perfomance of the engine. If the car has been unused for a few hours, the engine oil etc settles down. It is good idea to let it run after a cold start so the oil circulates in the engine. Keep in mind it's a 1996 model and needs more care. Keep servicing regularly.
Feb 06, 2014 | 2006 Honda Element
Pto wont engage when mower is hot
Hi
your PTO is built just like a wound up coil and becomes magnatized it gets real hot and it shorts out when it heats up make sure you have no frayed wires which will creat a large risistance and really heat up
Joe
Sep 09, 2012 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
The diagnostic connector on my 1990 Geo Prizm is dirty. Does this effect anything. It is hard to start when cold or has been sitting for a few hours. When it does start it runs rough for a few minutes...
if it contines to run fine dont mess with however if it starts acting out again sound like possibly loss of fuel pressure have it check next with gauge on fuel system allow it to sit overnight and see what gauge reads in am BEFORE trying to start engine let me know if you need help
Mar 07, 2011 | Geo Prizm Cars & Trucks
Engine cutting off after engaging the pto (mower deck) JD 317
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
