Question about Vehicle Parts & Accessories
What is the torque sequance for the intake manifold on a 2004 hyundai xg350l
What is the torque sequence for the intake manifold on a 2004 3.5L Hyundai XG350L?
  • 28 Answers
Here is the torque pattern and the torque spec is 14-16ft lbswhat is the torque sequance for the intake manifol - 108587997
Posted on Apr 23, 2014
Torque specs for 2004 saturn intake manifold 3.5
16ft lbs starting at center and working outward, alternating tightening evenly
Mar 14, 2015 | 2004 Saturn VUE
02 WIMDSTAR TORQUE SPECS INTAKE MANIFOLD AND SEQUENCE
always start in the middle, then work your way to the ends on alternating side bolts, bolts are probably 10mm or 3/8", if so around 18-24 ft/lbs torque maximum. don't use sealant on the intake manifold and the rocker cover should be 6mm or 1/4 bolts, same sequence just less torque, 10-12 in"/lb max
Jul 24, 2014 | 2002 Ford Windstar 3.8L Intake Manifold &...
Bolt torque sequence on 1991 jaguar xj6 4.0 intake manifold?
intake manifold or head gasket? i know head gasket need a sequential order followed by how many degrees and Lbs of pressure. if its on the intake i doubt it needs an specific torque. just try not to crack the intake manifold since its made of plastic.
Oct 29, 2012 | 1991 Jaguar XJ6
Need cylinder head torque specifications 2004 hyundai elantra
Install the cylinder head bolts. Starting at top center, tighten all cylinder head bolts in sequence as shown in illustration, using the Cylinder Head Bolt Wrench (09221 - 32001) or equivalent. Repeat the procedure, re-tightening all cylinder head bolt to the specified torque. (torque spec is Cold Engine 105-115 Nm (76-83 ft lb) )
. Install the timing belt tensioner pulley.
. Install the timing belt on the camshaft sprocket, making sure that the tension side is tightened by turning the camshaft sprocket in reverse, all timing marks are in alignment.
. Adjust the timing according to "Timing Belt"
. Install the rocker cover and tighten the bolts to the specified torque. Tightening torque: Rocker cover belt:
2.5-3.5 Nm (25-35 kg.cm, 2-3 ft. lbs.)
. Install the timing belt cover.
Install the new intake manifold gasket and the intake manifold. Tighten the nuts and bolts to the specified torque.
Install the new exhaust manifold gasket and the exhaust manifold. Tighten the exhaust manifold attaching nuts to the specified torque.
. Install the surge tank and tighten the nuts bolts to the specified torque.
. Install the power steering oil pump and bracket.
. Install the ignition coil.
. Install the air intake hose.
Connect the vacuum hose, fuel hose and water hose.
. Install breather hose.
Dec 22, 2010 | 2004 Hyundai Elantra
Looking for head bolt troque spec for 3.4l impala sfi04
Please don't forget to rate. Thank you:
Left side front cylinder head
Cylinder head bolt torque sequence-3.4L engine
  • Cylinder head by aligning it with the dowel pins
  • New cylinder head bolts coated with a sealant (such as GM 1052080). Torque the bolts in the proper sequence (1-8) to 37 ft. lbs. (50 Nm). Using a torque angle meter turn the bolts 90 degrees in the proper sequence.
  • Left side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plugs. Torque the plugs 11 ft. lbs. (15 Nm).
  • Right side rear cylinder head:
  • New cylinder head gasket
  • Cylinder head on top of the gasket and make certain it is lined up properly with the dowel pins
  • Right side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plug wires
  • Exhaust crossover pipe. Torque the fastener to 18 ft. lbs. (25 Nm).
  • Valve rocker arms and pushrods. Torque the fastener to 89 inch lbs. (10 Nm). Using a torque angle meter torque the fastener an additional 30 degrees.
  • Lower intake manifold. Torque the bolts to 115 inch lbs. (13 Nm).
  • Upper intake manifold. Torque the bolts to 18 ft. lbs. (25 Nm).
  • Nov 26, 2010 | 2004 Chevrolet Impala
    Need the torque specs for the upper intake bults on a 2002 chrysler sebring conv. 2.7L
    Fig. Intake manifold bolt torque sequence 2.7L engine
    Upper intake manifold with a new gasket on the lower intake manifold and torque the bolts, in sequence, to: 105 inch lbs. (12 Nm)
    Hope helps (remember to rate this answer). Good job.
    Oct 11, 2010 | 2002 Chrysler Sebring
    Need torque specs for a 2001 jeep cherokee intake manifold
    Intake manifold using new gaskets. Torque the bolts, in sequence, to 105 inch lbs. (12 Nm)...
    Fig. Intake manifold torque sequence-3.7 & 4.7L engines
    Hope this help (remember comment and rated this).
    May 07, 2010 | 2001 Jeep Cherokee
    Need to locate map sensor that regulates fuel to engine on hyundai xg350l engine.
    HI
    the MAP sensor locate on the intake manifold it have 3 wire connector and have a hose or pipe join to the intake manifold
    ask for more
    WITH MY BEST WISHES
    Jul 19, 2008 | Hyundai XG350 Cars & Trucks
    Vehicle Parts & Accessories Logo
    105 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
