Question about Califone Dual Cassette Music Maker Plus Stereo Learning Center
Cd starts to play and then stops turning and stops playing.
  • Califone Master
  • 1,267 Answers
Sounds like a power supply failure for part of the drive circuit.
Posted on Aug 02, 2015
How to turn it on to play CD?
Personal CD Players usually have a on/off button or sometime a play and stop button. links below,
press the helpful button
Playing portable CD player
Rio Portable MP3 CD Player
Sony Portable DVD player teardown repair
Top 10 Portable Cd Player
Feb 04, 2016 | Audio Players & Recorders
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
My sharp cd-ba200 will barley play cds
Put the player On for few hours or overnight. Now remove the panel and get access to the optical head unit, use a clean ear bud to polish the optical head. If not the optical head is weak and must be replaced.
Mar 14, 2012 | Sharp CD-BA200 CD Shelf System
Cd plays then stops
Hello
Check its connecting strip to laser picku unit to main baord. Replace it. Still the problem perists, replace the laser pickup unit.
Mar 02, 2012 | RCA RTB1100 Theater System
The cd player will start playing for seconds and then volume stop but cd keeps playing
are you running the deck through an amplifier? if so, you may be using the antenna remote wire (blue) instead of the amp remote (blue/white stripe) to turn the amp on.
Aug 11, 2010 | Car Audio & Video
I have no clue how to play a cd there... I mean, the radio is no problem, i can turn it off and on, can search for a prog, no big deal. but how do i start the turntable? maybe someone even has a manual for...
to start a turntable press Start button and put an arm with a needle across record, if there is no start button, just put arm across record - it should auto-start; to play cd put it in and press play (play button shoud be near the cd slot, together with stop, skip and others)
Oct 14, 2009 | Crosley CR711-BK AutoRama Retro Turntable...
Good day - I moved for my work and upon
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! Unplugg before opening!
Oct 12, 2009 | Yamaha CDC-665 CD Player
My Wurlitzer 1015 100 cd jukebox wont play cd's
The problem may be in the power supply, it could be dry (cold joints in the USA) joints that are giving you problems. If you have the manual try checking the voltages at the power supply before and after you get the problem. It could be that once the jukebox is aired that the problem starts.
Regards
Alan Hood
ami-man
UK
Jan 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
CD player acknowledge CD, starts to play, then stops
I belevie you have problem in laser assembly it might not worth to repair it
Cheers
Dec 10, 2008 | Audio Players & Recorders
Califone Dual Cassette Music Maker Plus Stereo Learning Center Logo
51 people viewed this question
Top Califone Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Califone Audio Player and Recorder Expert? Answer questions, earn points and help others
