Question about Electronics - Others
Hi, sounds like you understand power converters. I have a 96 Hitchhiker fifth wheel with a 40 amp magnatex converter with bat. chager. The problem I have is that is does not charge the battery with the genarator or 110 direct power. It does charge with the trailer conection.? I do also get power from the 110 line or genarator but only parts of the trailer. Nothing seams to work through the converter. I have checked all fuses and breakers and they look ok. Any thoughts or ideas would be much apreciated. I no nothing about converters and how they work. How do tell if a converter is bad? I know it has power to the converter but that as far as I can track. Thanks so much.. Scott.. Denver Colorado 1share@live.com
  • Craig Butler
    Craig Butler May 11, 2010
    Do you still need help? I can help you...
    President:
  • 1,714 Answers
It sounds like you may have some wiring issues. The inverter simply changes DC battery voltage to 120 volts AC. This will allow you to have AC voltage without running a generator.(noise issue).You probably need to find a well recommended RV repair shop and have a tech look things over.
Posted on Jul 07, 2009
What kind of generator for a 1978 Wilderness trailer
1978 Wilderness Prices, Values and Specs Building travel trailers as well as fifth wheel trailers for the first time in the 1970s, recreational vehicle brand Wilderness designed as basic family vacationing and camping. Wilderness would also produce park model vacation units from 1994 to 2002 measuring up to 40 feet in length. A division of Fleetwood, Wilderness was discontinued after the 2009 model year.
Mar 27, 2017 | Televison & Video
Where is the converter for a 2004 Alpenlite fifth wheel camper
Look where your breaker panel is, or close to where power cable enters trailer.
Apr 11, 2015 | RVs
Battery is installed properly and keeps blowing 40 amp fuse on the out put side.
Hi there, Ive had the same problem that came from a worn out wire that was toucing, this may be the problem.
May 26, 2014 | Parallax Power Supply PARALLAX POWER 7465...
96 Benz ran out of gas other day, got it filled up & drove home (20 miles). Next day drove about 40 miles, left car running in park for about 15 min, when I left car was stalling like it was running o
You never leave a car running, as it will
overheat the Exhaust Converter
When you run out of fuel, you sometimes
ruin the Fuel Pump
It depends on gas to lubricate it,as strange as it sounds
Check fuel pressure & volume at the motor with a gauge
Jul 20, 2013 | Cars & Trucks
How to install Scosche - 2-Channel Adjustable Line-Out Converter
If it is an active converter and not passive, you should have three power wires, black goes to ground, yellow to battery, and red to the remote/amp (blue) wire off the deck. Then there should be four input wires. These connect to your speakers, white-white/black to left, grey-grey/black to right. Black line indicates ground, or (-). Then simply hook up the RCA jacks to your amp! Caution: the Scosche only accepts 80w of power, 40 per channel. Otherwise you rick blowing the converter, possibly the amp (usually a mosfet), and then possibly the subs, though not likely.
Mar 05, 2010 | 1999 Ford Explorer
86 5th ave lacking power to drive faster than 40km/h
Sounds like your cat converter has become clogged from diesel....take it to a smog tester to see if cat is bad
Jun 27, 2009 | 1986 Chrysler Fifth Avenue
Install a second DuoTherm A/C in a fifth wheel travel trailer.
You do not without removing wall board. You can do a nice neat job of white conduit on the outside of the wall and ceiling. I have done it and my customers are happy with it.
www.coachtech.info
Mar 19, 2009 | Dometic Rooftop RV Air Conditioner
96 jeep grand cherokee
If it is the fuse for major engine control electronics that is blowing (PCM, etc.) as soon after energizing, try disconnecting the O2 sensors. The 12V heater in the sensor could be shorting to ground.
Nov 17, 2008 | 1996 Jeep Grand Cherokee
Electronics - Others Logo
244 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
