Question about Cell Phones
Blackberry pairing FOFLO - Cell Phones
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
Cannot pair blackberry 8520 with parrot ck3100
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
Unable to pair bluetooth Plantronic 975 with BlackBerry 9700
On your Blackberry, navigate to Options,Bluetooth,Hit the cursor, Select Options, Set Discoverable to Yes, and save.
Make sure your Plantronic is in pairing mode.
On the Blackberry, hit the return key, add device, Search, Pllantronic will be listed on the blackberry as found. Select it, and add the password which by default is 0000.
Feb 10, 2010 | Cell Phones
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Pairing Jawbone 2 with BlackBerry 8700
Just put your jawbone in pairing mode, usually by press and holding the on button for about 10 seconds. you should see the light flash blue and red alternately.The go to options on your BB and bluetooth then press the ball and add device you will have an option for allow another to find me, click it and when your jawbone pairs put in the default code which should be 0000 or 1234
you device will pair and your set
Jun 03, 2009 | HTC G1 Smartphone
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
