Question about Hand Tools
I volunteered to look at a stihl strimmer carb, after the local stihl shop lost all gaskets, and possibly another part. would it be possible to have a diagram breakdown of an rb66 carb so i can work out which part they have lost. thank you. arowe46@hotmail.com
  • 3,600 Answers
Here is the web site that you can request the information from. You can alos get it from the local dealer. as you may know they try to keep the information for dealers and owwners only. http://www.toolsupplystore.com/stihl-ts420-petrol-cutoff-saw-350mm-p-11682.html?gclid=CJvPyPTXwZwCFRYiagodk1b0oA
Posted on Aug 26, 2009
I am rebuilding a Stihl trimmer model FS 110 R carburetor and I need to know what gaskets to use and where they go
You will need to remove the carb and see who made it as most manufacturer buy there carbs. , ie: walboro, it will have a marking on it along with the carb number such as wt784. Then you can go to ebay or your local lawn mower shop and they should have the rebuild kit. It cost about 4 to 6 dollars. Just reassemble it the same as you take it apart. When you take the jets out be sure to count the turns and then you can put them back when you are done. In addition if you look real close, because the stamp are tiny you will see a L for low idle and H for high speed. Hope this helps.
Jun 04, 2017 | Stihl Garden
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
My stihl saw ts410 runs ok but as soon as you come to rev it ,it cuts out can you help
try setting your carb, you will see three holes at the side of the machine nr to the fuel cap. the one at the bottom screw it in as far as it will go then unscrew it 4 turns, the one above it do the same again but unscrew it one and a half turns, if this dont work its possible draging air in from somwere ie, crank seals, inpluse pipe, gaskets. it will need to be presure tested.
Feb 15, 2015 | Stihl Ts 410 420 Cut Off Saw...
Echo srm2000b strimmer - has good compression but no induction
  • Check your muffler's spark arrestor screen. It could be plugged with carbon and not allowing the engine to breathe.
  • Another good possibility is bad gaskets/seals in the crankcase or just loose screws. A vacuum and pressure test of the engine should find these.
Jan 04, 2015 | Echo Garden
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
if you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Apr 15, 2014 | Stihl Garden
Leaf blowers
Your local Stihl dealer would be the best place to get a carb, but you can save money by shopping round online. I have used L&S engineering in the past. But it depends where you are in the world. :)
Feb 12, 2013 | Stihl Garden
Brand new royobi strimmer RLT30CET will not start very easily , even foll owing manufactoure instructions. could anybody explain why? Dave F
The manufacturer's of the cheaper "big BOX stores" trimmer carburetors are made in foreign lands, with adjustments basically set to their liking. Ryobis use ZAMA and RUEIING carburetors. Mexico and China are just 2 of the foreign places they are made. Unfortunately, the factory settings don't always work well in the locale the machine is sold in.This is POSSIBLY one of your problems.Higher end trimmer manufacturers set up their machines (eg. Stihl, Echo, Kawasaki, Husqvarna) prior to selling them. The carbs get adjusted for the local climate.Elevation effects carb function a good deal. A standard diaphragm carb is dependent upon the atmospheric pressure to work. Try to check if the carb is adjusted properly, first. Here is a tutorial.
http://www.zamacarb.com/tipspage.html
Mar 04, 2011 | Ryobi Garden
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Jun 01, 2009 | Black & Decker Garden
Starts ok wont pick up speed
check to see if the throttle cable is hooked up to the carb. look at the back of the motor and watch as you pull the the throttle to see if the cable is hooked up. if the cable looks to be working correctly then pull the spark plug up and heat it up with a blow torch and put it back in. if the motor runs good then you need a new spark plug. if those two things do not work then you need to replace the carb diapram and gaskets.
hatter1
May 18, 2009 | Yard Machines Garden
Hand Tools Logo
203 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
