Question about Technics SL-1200MK2 Turntable
Sound cuts out on one side when playing record i have checked the rca connectors they seem to be fine
  • 382 Answers
The issue will mostly likely be the tonearm, rca's and/or the rca leads.
Reverse the connections on the mixer to eliminate the input rca's on the mixer and isolate the channel at fault.
Reseat the headshell/cartridge assembly.
Replace the stylus.
If after these 3 steps, the issue persists, then it is actually is an internal issue, and the RCA's and/or tonearm may need to be replaced.
Check it..
Posted on Nov 02, 2007
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work.
Jul 18, 2015 | Panasonic Televison & Video
Poor sound quality from external line
it may be the recorder itself.. these smaller recorders arent known for excellent recording quality..what is it set for..also check the recording lens and clean with a duster may be dirty..
Jan 19, 2014 | Tascam BB-1000 Portable CD/SD Recorder
Sound cuts out on one channel while playing LP records VSX-1022
you have a short in the rca cable from phono to reciver. try a new cable. if problem is still there i would say your record player is shorted inside.
Mar 13, 2013 | Pioneer Vsx-1022-K 7.1 Home Theater...
RCA cdrw 121 recording shuts down at 41 minutes
Depending on the age of the unit the linear sled may have a blockage in the worm gear t that point. Does it play a disc all the way through or does it stop at 41 minutes too. This would be a hint. Make sure you are not recording in a high resolution mode which will cut down on time.
Jan 22, 2013 | RCA CDRW121 2-Disc CD Recorder
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
Jul 15, 2011 | Audio Players & Recorders
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
Pioneer PL200 very low volume in one channel
its most likely a break in the rca phono leads coming out of the rear of the deck? maybe try jiggling them whilst playing a record to see if the sound comes on? if this is the case you could maybe locate by jiggling up and down the cable till you locate where the break is and cut of the cable, add a new phono by usung an electrical joint connector (the type electricians use to joint two wires via plastic connector with screws in?) and see if this solves it? failing that get the rca phonos completely rewired by a competent repairer? good luck
Sep 13, 2009 | Technics SL-1210 Turntable
Some sounds are lower in songs
Well, it seems you answered your own question. Replace your stylus. If that doesn't solve your problem, the issue might be your RCA cables or tonearm.
What many people don't understand is that it takes ALOT to wear out a record. I mean, you would have to play a record about a good 1000 times before you'll see any sort of real wear/tear on it. Why do you think they last so long? Besides, record wear doesn't sound like that. With TRUE record wear you'll experience lots of skipping from your stylus, as the grooves have worn down. Also, you'll get alot of pan issues, where the sound goes in/out left/right side. The grooves of a record are a V shape, and the left side of the V carries the left signal, and the right side carries the right signal. With record wear, usually 1 side will wear out quicker than the other, and that's why you'll get inconsistencies with sound.
Unless you play the same record over and over again for the past few years, you wont see this kind of wear.
Replace your stylus first, then have your RCA cables and tonearm checked. Try cleaning out your tonearm with 99.9% PURE ISOPROPYL ALCOHOL and see if that does anything.
Good luck
Jan 02, 2008 | Technics SL-1200MK2 Turntable
Intermitent audio
I had that happen before, one problem was my car had bad shocks or i hit a pothole in the road. The second time i had the volume up so loud the bass wass thumping the floor and it skips the CD. My question is, how lowd is the thign turned up? :P Some CD players load the data into a memory and then it plays from the memory till it needs more info. It maybe that the unit is not stable or the CD is not balanced right so it cant read the info at a consistant speed. The music maybe playing faster then it can read because of the vibrations. Is the disk clean? i know this may sound dumb but it is easy to over look. If the surface of the data side is so scratched up it may have problems reading the data quickly enough. Sometimes the coating can fall of the disk if you hold it in the light you can sometimes see spots threw the disk where the foil has been chipped off. The CD player could have a focus problem also, it could be damaged in shipping or have been dropped and it cant focus properly on the data. Do you have any other disks to try? a new one? one you never play?
Apr 04, 2006 | Philips CDR785 3-Disc CD Recorder
Technics SL-1200MK2 Turntable Logo
477 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
