Question about Gestetner Office Equipment & Supplies
Drum needs to be replaced'
Replaced photo conductor unit
  • 13 Answers
SOURCE: Counters
It should be under Utilities menu -> Reset Photoconductor Counter.
Posted on Nov 19, 2007
Arius
  • 446 Answers
SOURCE: Color Photo Conductor Unit
the vertical line that you saw is an indication of either it is normally worn out, or something has caused the scratched, by any material ( PC drum is very sensitive to any material and can easily damaged or scratched any solid and unwanted dirt inside) see you actual meter reading. if it falls on the first thousand copies or print then it might have caused by a scratched, if it falls beyond the PM parts repalcement then there is nothing you can do but to replace this.
sometimes you can swap the colors, by the affected color use the yellow drum unit to the affected drum, the vertical would not that be obvious.
Posted on Jul 24, 2008
  • 40 Answers
SOURCE: Kyocera 1810 drum replacement
If you have some mechanical skills and a steady hand you can change the drum. However it worth the money to pay a "pro"to do it. Also you may want to replace the cleaning blade too.
1. Open the front cover - where the toner is.
2. Remove the black cover - 2 screws
3. Remove a little stopper at the bottom of the drum unit + 1 screw
4. Disconnect the drum unit cable.
5. Take off 2 screws which secure the Drum Unit.
6. On top of the Drum unit you should see 2 white plastic stoppers - front and back side ends - You have to push them inside to keep the cleanng blade away from the drum.
7. Remove the MCH assembley - 1 screw.
8. Remove the front separation claws + plate - 2 screws.
9. Remove the Drum Shaft
10. Replace the Drum
There are few details about how to manipulate a Drum - Do not touch the surface, do not expose it to intense light...
8.
Posted on Jan 12, 2009
  • 9 Answers
SOURCE: Aficio CL3500N Photo Conductor Unit
If your print outs are clear and the PCU is surely new.
Press Menu
Scroll to Maintenance <Press Enter>
Scroll to Replacmnt Alert <Press Enter>\
Scroll to PCU <Press Enter>
Select Notify Later <Press Enter>
Good luck.
Posted on Apr 06, 2009
SOURCE: How to replace drum unit
open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
Posted on May 26, 2009
What is a photo conductor
The photo conductor is the round drum unit that is light sensitive. The laser in the printer writes an image of what you want to print on the drum and then the toner is applied to the drum and transferred to the paper.
Aug 30, 2015 | Ricoh Aficio 1515MF All-In-One Laser...
How to clean Ricoh Aficio MP 2000
sounds like either drum blade has fail or drum is bad. try printing the counter report and see if it is doing this. Then photo conductor unit needs to be rebuilt or replace. open right side door and look at drum make sure you don't touch it and see if toner is on it. If so drum blade has fail. call a tech or buy new photo conductor unit. this are good for approx 60,000 copies but sometimes will go longer age also play with drum blade life. were you might have 20,000 copies but unit is 5 years old
Jan 31, 2012 | Ricoh Aficio MP 2000 Black and White...
In Konica Minolta bizhub 362 it says ready to copy but I noticed it says "please change PC drum"
Thecopier has a counter the drum unit. "PC" means photo conductor, I don't remember if the copier will lock up if the drum unit is not replaced? There is a counter that needs to be reset once the drum & new developer is installed.
Jul 19, 2011 | Office Equipment & Supplies
IS THERE A TRICK TO INSTALLING THE PCU ON THE CL3500N? IT SEEMS AS THOUGH IT SHOULD BE A SIMPLE PROCESS HOWEVER IT IS NOT LOCKING INTO PLACE. THANK YOU
Photo Conductor Unit Color
A Turn off the power, and then unplug the power cable.
B Open the right cover.
C Pull out the green levers on the left and right that are securing the inner
cover.Replacing
D Lift the inner cover until it stays up.
E Remove the photo conductor unit.
F Pinch the
green lever to unlock the unit.
G Pull out the photo conductor unit carefully.
H Pinch the green lever to unlock the unit.
I Pull out the photo conductor unit carefully until it stops.
J Pinch the green part to release the unit
.K Pull out the photo conductor unit carefully. Be sure to hold the unit with both hands, and pull it out carefully.
L Take out the new photo conductor unit.
M Remove the cap attached to the photo conductor unit. The cap is no longer needed and can be disposed of.
N Remove the tape from around Photo Conductor Unit by peeling it down-ward, and then remove the unit
Mar 11, 2011 | Ricoh Aficio CL3500N Laser Printer
After a few copies are made, black streaks start showing up on the copies and gets worse with each successive copy
for most copier those black streaks are caused by poor cleaning of the Photo Conductor Drum these can be fix by replacing the cleaning blade. after replacing them clean the Photo Conductor Unit and make some test copies.
Feb 27, 2010 | Office Equipment & Supplies
May 25, 2009 | Lanier Office Equipment & Supplies
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
Pc drum
Replacement of the Photo Conductor Unit
1. Select Tech. Rep. Mode → [Counter] → [Special Parts Counter] → [PC Life].
2. Press the Clear key to clear the counter value.
3. Turn OFF the main power switch.
NOTE
• Clear the PC Life counter before removing the IU.
• After clearing the PC Life counter, be sure to turn OFF the main power switch.
4. Open the Right Door.
5. Remove the IU. Carefully pull on the two green handles
6. Remove four screws (silver) on the sides and disassemble the Photo Conductor from the Developing Unit.
7. Replace the Photo Conductor Unit
8. To reinstall, reverse the order of
removal.
NOTE
• Replace the Toner Filter (Developing
Unit) with a new one at the same
time.
Jun 06, 2008 | Office Equipment & Supplies
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
Sep 12, 2007 | Ricoh CL3000E Laser Printer
12 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
