Question about Brother MFC-5460CN All-In-One InkJet Printer
Remove scanner glass
How do you remove and clean underneath the scanner glass.
2 Suggested Answers
marketex
  • 371 Answers
SOURCE: Brother MFC-210C, need to clean the scan glass underneath.
I know that you want to get at the fungus, but disassembly is not your biggest problem.
Reassembly and realignment of your scanner is your biggest problem.
Consider the following and tell me whether it is worth the trouble.
Seller rating Tax and shipping Total price Base price ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 27 seller ratings
No tax + Shipping: $9.00 $12.75 $3.75
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 530 seller ratings
Tax: $11.34 + Shipping: $19.11 $163.81 $133.36
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 16 seller ratings
No tax + Shipping: $20.00 $119.89 $99.89
3 seller ratings
$7.95
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 1,356 seller ratings
$122.99
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 67 seller ratings
$139.28
Posted on Apr 09, 2009
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
There is Dark spots on paper when a photocopy is done
Most likely there is something on the glass or something ie: dust underneath the glass that gets in the way of the scanner and the paper(dots) or on the scanner itself(streak). I have heard many times that photocopy machines in cvs/wall greens, any kind of commercial copy places and even libraries deliberately mark on the glass with permanent marker to prevent any kind of copy fraud. You can clean the glass with rubbing alcohol or goof off to remove any stubborn ink on the glass and then use some Windex or something, but if its underneath the glass or on the scanner bar you will need to take some stuff apart clean it and place it back. IF you do that make sure its SUPER clean and you dont leave any finger prints on it
Feb 04, 2014 | Sharp AR-M207 All-In-One Laser Printer
BLACK LINES APPEAR WHILE SCANNING WITH hp SCANJET
mirrors underneath the glass are dirty or "fogged up" . Remove the glass if possible and clean the mirrors carefully with q-tips.
Dec 25, 2010 | HP ScanJet 2300C Flatbed Scanner
Cleaning the glass
USUALLY you remove screws from the bottom of the unit and lift off the top. Not familiar with the unit.
Sep 25, 2009 | Epson 2580 Perfection Photo Scanner
Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
Mar 02, 2009 | Ricoh Aficio 2015 Copier
Hp 7400c haze on INSIDE of scanner glass
I figured this one out.
There is a language panel on the front (that tells you what each button does). The original instructions mentioned putting the panel on but not taking it off. If you use a small, thin screwdriver or thin, dull knife from underneath, you can work your way across the bottom edge, popping off the language panel. When you remove the panel you reveal three screws, one rather tiny one in the center toward the bottom, and two medium sized ones to the sides closer to the top. Slide the glass cover up and off. There are two more medium sized screws near the slots for the cover. Remove all five screws. The assembly with the glass comes right off, allowing you to clean both sides.
Dec 14, 2008 | HP Scanjet 7400c Flatbed Scanner
Ever Smart Jazz Scanner
you cannot.... mmmmmwhhhhhaaaahahahahahahhahahaha
Jun 09, 2008 | CreoScitex EverSmart Jazz Flatbed Scanner
Clean glass on MP830?
Best left alone this one, even printer technicians dont remove glass on the scanner unit they just replace the whole scanner assembly, the reason? there are a lot of plastic clips holding it together and springs and cables that are easily dislodged,
often the improvement in scan quality isn't as great as one would think.
the scanner assembly can be replaced as a unit for around $200
May 31, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
Cleaning scanner glass
This solution is for the HP 3310 all-in-one.
How to clean under the glass.
1. Find the small wire that runs from the lid to a jack on the back and disconnect it, un-clip the wire from the holders and let it hang free.
2. Lift the lid and pull it straight up about 3/4 of an inch, you will see two indents in the hinge, push these one at a time to release the lid. Remove it completely.
3. 3 screws are located under the hinge, remove them as well as the two in the front.
4. In the back, gently pull on the silver end pieces to release the top from the unit.
5. You can now turn it over to clean the glass.
6. to reinstall reverse the steps and remember to plug the jack back in.
That's it, easy when you know how. Pay HP service nothing!
May 28, 2007 | HP Photosmart 3310 Printer
Brother MFC-5460CN All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
