Question about Epson DFX-9000 Matrix Printer
DXF-9000 EPSON ERROR 03 - Epson DFX-9000 Matrix Printer
ohms
  • 1879 Answers
SOURCE: epson dfx-9000
the SP motor brake signal didn't switch on within 3 seconds after turning printer on.
check for disconnected SP motor-related connectors. the printer needs servicing.
Posted on Jan 22, 2008
ohms
  • 1879 Answers
SOURCE: error 09 on epson dfx900
Greetings,
FAN1 Driver Error
Check connections for the Fan 1
I suggest calling the manufacturer if that unit is still under warranty.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 28, 2008
Inky
  • 691 Answers
SOURCE: EPSON DFX 9000 DISPLAYING ERROR O F
This error occurs when the Home Position (HP) of the Automatic Paper Thickness Control (APTC) mechanism is not detected.
This error is caused by a malfunction of either the APTC HP sensor circuit, the APTC motor, or the driver circuit on the ROM Board.
Check the following in the order below, testing functionality at each step. If the APTC motor has malfunctioned, be sure to check the motor driver circuit on the ROM Board before replacing the motor.
1. Check connectors CNSEN1 and CNSEN2 on the ROM BOARD.
2. Check and replace the APTC HP UNIT
3. Check both the APTC motor, APTC UNIT, ROM BOARD, and replace either or both as necessary.
Get a service manual HERE if you need it.
Posted on Jul 23, 2008
SOURCE: error 07 ,turn off Printer on dfx 9000
Timing fence could be faulty or dusty. Clean it and test if that fails replace it.
Posted on Apr 03, 2009
SOURCE: error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Posted on Dec 03, 2009
What does error 03 indicate?
Fatal Error Code 03: CR Horizontal Position Error
The SP motor brake signal did not switch on within 3 seconds after
turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM
BOARD: CNSPHS, CNSPM), See 4.2.3.3 SENSOR BOARD
UNIT (p.139).
2. Check the Interlock switch, and if necessary replace the
INLK SW ASY (p.146).
3. Check both the SP motor and driver. (Always check both.) Check for a broken fuse on the SP motor 42 V line. Replace the
SP MOTOR ASY (p.156), and/or ROM BOARD (p.137) as necessary.
Epson DFX 9000 Service Manual Troubleshooting Based On Error Codes
Mar 28, 2016 | Epson DFX-9000 Matrix Printer
What is the meaning of "ERROR 03 on my dfx 9000
you have to clean the CARRIER ENCODE SENSOR SCALE
which is a <<tape>> under the printhead and detects the movement of the cr assembly
Aug 18, 2014 | Epson DFX-9000 Matrix Printer
Error 03 and it says shutdown printer
hello , be fresh . what is the meaning of error 03 ?
Jan 08, 2010 | Epson DFX-9000 Matrix Printer
Error 03 turn off printer
please check some cable connector if the theres some disconnections... inside the printer.
Jun 16, 2009 | Epson DFX-9000 Matrix Printer
Error13 for epson printer dfx 9000
ALLO CHO MINH HOI MAY IN KIM EPSON DFX 9000 BAO LOI ERROR 03 LA BI PAN GI VAY ?
Mar 18, 2009 | Epson DFX-9000 Matrix Printer
DFX 9000 Printer on display Error 03 plz help out.
DFX 9000 Máy in L?»?i hi?»?n th?»? trên 03
Jan 11, 2009 | Epson DFX-9000 Matrix Printer
Printer repair
carriage load measurement error-chances are you will have to sendit to a servicer to have it fix
Mar 26, 2008 | Epson DFX-9000 Matrix Printer
Epson dfx-9000
Jan 15, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
