Question about Sewing Machines
Spring missing on bobbin winder on babylock esante
SOURCE: Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
Posted on Mar 25, 2008
  • 14 Answers
SOURCE: bobbin doesn't fill in bobbin winder
The bobbin winder question is a frequent one and it is very easy to solve. If you look at the shaft where the bobbin sits on the bobbin winder, you will notice that it has a slot in the middle of the shaft, an opening if you will. This is where you use a flat screw driver and open that space more to give more friction to the bobbin so it is not loose on the shaft. That slot was made for that. There are different bobbins on the market so thats why the slot is there. If it is too tight, grab a pair of pliers and close the gap. The metal of the bobbin winder on that shaft is malleable exactly for this reason. No need to put plastic bag material or anything like that. Use it as it was intended for.
Posted on Jul 08, 2008
RickE1
  • 202 Answers
SOURCE: Bobbin winder will not turn..
Without knowing what type of machine you have its hard to determine if the problem is mechanical or electronic. If the bobbinwinder has its own motor than its probably electronic and it could be a bad motor or circuitboard. Sounds like this could be it.
The minimum service charge could be about 50.00 but this won't include the more expensive part. You might look up Sidewinder bobbinwinders which is a small separate unit you can purchase in most fabric stores or online for about 20.00 and just wind bobbins separate from the machine.
Good luck.
Posted on Dec 20, 2008
  • 980 Answers
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
Posted on Nov 22, 2009
SOURCE: looking for a babylock esante manual. ESe2. The
I have a manual for the ESe2. If you still need it let me know
Posted on Feb 17, 2010
Where does the tension spri ng go on my babylock 1550 bobbin winder
It may be worthwhile to purchase a new bobbin case for your machine. Trying to re-attach the spring will most likely cause the spring tension to change making it difficult to get the tension correct. Bobbin cases do wear out and really are not all that expensive to purchase. A lot of sewists keep more than one bobbin case on hand so they can adjust a specific case to accommodate the tension for specific thread weights.
Dec 29, 2016 | Sewing Machines
Getting the cover off my brother cs 80. all screws have been removed and the cover comes off partially. I seems to be stuck at the turn wheel, like something is holding it fixed.
I had the same problem when opening my machine. The problem is a screw underneath the bobbin winder area. Pull the bobbin base off and then gently pull up the bobbin winder assembly from under the front cover. You will see a screw in the corner to remove so that you can complete the task. I had to purchase a service manual and then I had great success with replacing the bobbin winder "tire" (Bobbin Winder Tire, Babylock, Brother #X55238051 at sewingpartsonline.com - $3.99!!)
My bobbin winder works like a charm now. Sewing Parts Online Search
Sep 09, 2013 | Brother CS-80
I need a DVD manual for esante
you would have to contact babylock customer service or a babylock
dealer to see if they have a dvd on the esante
or see if they have a downloadable manual.
Dec 21, 2012 | Baby Lock Esante
Babylock Esante stopped. Just makes loud noise but won't move even manually.
You probably have a jam. Start digging under the bobbin area.
If you get it all cleaned up under there... and it still won't move. Time for service by a pro. Could be something horrid like a bent shaft.
Good luck
Nov 03, 2012 | Baby Lock Sewing Machines
I inherited an Esante baby loc, golden anniversary limited edition. Unfortunately the manual was missing. I have searched everywhere with no luck. Any advice!
There is manual downloads from the Babylock website, I can't see this model but can see the Esante BLN, take a look, it may well be close enough to get you going. Otherwise you can contact BabyLock using their "Contact Us" page at the bottom of their home page, www.babylock.com.
http://babylock.com/ftp/whitepapers/Esante_BLN_InstructionRef.pdf
Jan 05, 2012 | Baby Lock Esante
Where do I get cards for my Esante?
Brother makes nearly all Babylock sewing machines, including the Esante, you can get cards from any Brother or Babylock dealer.
NOTE: The Brother "Disney" cards won't work in any Babylock.
Jan 15, 2011 | Baby Lock Esante
Looking for a babylock esante manual. ESe2. The
Nov 16, 2009 | Baby Lock Esante
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Can't see LCD on Babylock Esante
When your BabyLock Esante ESi2 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the BabyLock Esante ESi2 LCD screen, or buy a new machine. BabyLock no longer stock this item direct, but there is an affordable replacement available....Check this Link
Feb 28, 2009 | Baby Lock Esante
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
