Question about Samsung WF337AA Front Load Washer
In the spin cycle washer is noisy and shaking
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
Kenmore HE low water washer: The machine has become extremely noisy when spinning out. Sounds as if the bearings are going outing the lower section of the unit. Any advice?
its possible, but since I dont know the age of the washer, its hard to say.
I would open the door and reach in there and try and give it a good shake around and see if you can feel anything loose.
my mom has a HE low water washer and if its not loaded right, or got to many clothes or oddly weighed/shaped items in it, its noisy during spin out.
theres a possibly that the washer is not securely level anymore cause it to shake about on spin out. If this is the case, if you was staring at it while it was doing it you probably would notice it shaking about, just amazing what can happen when something spins at high speeds.. its why car motors are so finely precise in engineering, they spin so fast, any imperfection would cause a disaster.
Nov 01, 2013 | Washing Machines
Noisy on spin cycle "rattling"
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Washing machine
buy a new washer,the spider gear is gone probably from to much detergent,it's around 500 bucks for the part
Feb 11, 2010 | LG WM-2277HW Front Load Washer
Noisy & shaking spin cycle and smell
The shaking could be your shocks beginning to go bad, an unbalanced load, unbalanced machine, or even possibly weak flooring. As far as the smell you can purchase a product called "AFFRESH" at your local parts distributor which works well to removed the mildew in the gasket. You just put the tablets in and run the machine through a cycle. You could also wipe the gasket out with a wet rag.
Be sure to leave the door cracked open between cycles this will help prevent mildew from building up.
Hope this helps _MJ_
Jan 28, 2010 | Frigidaire Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Samsung WF337AA Front Load Washer Logo
16 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
