Question about Mtd 19 In. 173 CC OHV 3-In-1
Lawn mower wont start after oil change - Mtd 19 In. 173 CC OHV 3-In-1
    Loyalty:
    Visited the website for 30 consecutive days.
  • Mtd Master
  • 1,430 Answers
I can only check for spark if you have spark then go to the carb. check for fuel flow if you have flow clean your carb. one of these is bad.
Posted on Sep 19, 2017
  • 376 Answers
SOURCE: how to change oil and where i put the oil in to
Warm up the engine so the oil will flow out. Push the handle to the ground and either have someone stand on it or wedge it underneath something to hold it down. Disconnect spark plug!! Remove blade. Place a drain pan underneath mower (one that's shallow enough to lower the mower down on) and using a 3/8 extension on a ratchet, stick the square end of the extension in the drain plug in the bottom of the engine and unscrew. Lower mower back down for a couple of minutes then reverse proceedure. I think it holds about 20 oz. of oil. Put in 18 oz. and check it. Be sure not to overfill.
Posted on Jun 03, 2009
buffalonyman
  • 1865 Answers
SOURCE: Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Posted on Jun 12, 2009
canbruce75
  • 1776 Answers
SOURCE: GOT GASOLINE IN OIL TANK.
Empty the tank of the tainted gasoline (Maybe add the right amount of oil and use it for a trimmer, etc), fill tank with fresh gas and clean the spark plug, since it is probably fouled out. You may have to clean the carb with some carb cleaner, and clean your plug a few extra times, but it should be fine. Hope this helps. Good luck.
Posted on Jul 15, 2009
mowerman1857
  • 389 Answers
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
Posted on Sep 14, 2009
rwvanlue
  • 486 Answers
SOURCE: oil change in yard man lawn mower
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Dec 06, 2009
Vita 35 classic lawn mower not starting after tilting 2 change blades.
Use some staring fluid to get it going and that will burn off the oil.
Sep 04, 2016 | Garden
What happens to the lawn mower ir ite run with too much oil in it and why wont it run?
if you run a lawn mower with to much oil in it will smoke and foul the plug it will cause the engine not to run so chang the plug and start the engine with the oil at the right level
Aug 14, 2014 | Garden
Mower wont start changed plug still wont start checked gas line seemed okay but what is that plastic piece in the line never seen one before
Getting a mower out of its winter slumber takes some time. Start with fresh gas, new oil, and air filter. Sometimes carbs get gummed up(varnisized gas). Donyboy73 on youtube shows how to remove Briggs n Stratton in tank carb systems and clean the parts and passages.
Apr 27, 2013 | Toro Power Lawn Mower
Lawnmower wont start
check your sparkplug clean or replace, also crank it several times without sparkplug in it to blow out the cylinder, did you have it on it's side for anything?
Jun 05, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Mtd 19 In. 173 CC OHV 3-In-1 Logo
61 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
