Question about ASUS Computers & Internet
Fc ce d33005
MB won't power up. replaced switch and power cord. little green light on MB is flickering.
BoiseLCD
  • 63 Answers
SOURCE: dead samsung 172n power light flickers
Have you checked the power output from the power board? Is it constant and steady? Try reflowing all the joints if you haven't already. Especially transformer and coil joints. Maybe a bad logic board? Do you have spares to try? Does it do this with everything disconnected from the pwr board (switch, logic, inverter)?
Posted on Jan 03, 2009
tommya300
  • 724 Answers
SOURCE: HP Deskjet 9800 will not power up.
Is there power coming out from the supply end
Is is a DC or and AC output supply?
If is it an AC output supply tyhebm in the back of the HP had an AC to DC converted that is realy a diode bridge and should contain a fuse in the circuit somewhere on that board
Posted on Jul 27, 2009
joez47
  • 61 Answers
SOURCE: tv won;t turn on little green light flashes on power button
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Posted on Sep 13, 2009
budmrtn
  • 11361 Answers
SOURCE: The DELL E172FPb LCD Monitor (switch light flicks green)scr black
You need to open it up and inspect the componente inside, look at the fuse and the transistors in the inverter circuits first, also look for sign of over heating on the board, see pictures here for the guide: http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 20, 2010
  • 89 Answers
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
Posted on Jun 07, 2010
Have dell Inspiron 546 minitower. Been acting up lately where it won't power up. The LED light on PSU below voltage switch is green. Light on MB is orange. No power or indication at all on front...
PSU's put out several different voltages if the 12Vs isn't working it won't power the motherboard. Some outputs may still be functioning therefore you may see some lights on and even some fans running. Replace the PSU.
Jun 29, 2013 | Computers & Internet
Won't start up little green light flashing on back
the green light flashing on the backside is your internetconnection.
about the computer wan't start i should check the PSU do the fan movs any light on the motherboard.if not is the electric cord firmly and tight in place.if the fans runs and lights on the motherboard.you got no picture proberly brooken videocard.
Apr 11, 2013 | Computers & Internet
Power flickered during thunderstorm, TV wont come back on. heard little pop from tv when lights flickered.
Unplug it and take the back off. Look too see if the fuse right next to the power cord is black. Replace it. If it pops again, you have damaged the board and need a repair guy. Look for any burnt parts before replacing the fuse.
Jun 16, 2011 | Panasonic CT-32D12D 32" TV
HP Pavilion a 1020n desktop - green power supply light on back flickers \ pulses when power cord is in place, but system will not respond when the power on button is pressed.
just remove the ATX cable from the motherboard (24 pins connector coming from the power supply),the power cable to the HDD and the and the dvd drive and then connect the power and chekc whether the light stays on or flicker ,if it flickers then the power supply is Bad if not then there is a probelm with the motherboard
Mar 01, 2011 | HP Pavilion a1020n (PS583AA) PC Desktop
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Feb 02, 2010 | AOpen S651M (918EM10S50) Motherboard
My pc gets no power the flashing green light doesn't come on no fan nothing happens when i press the power button
best guess bad motherboard or bad power supply.
things to test:
1. Check that the power cord is plugged in snugly to the back of the computer and connected to a working power outlet or surge protector.
2. Check that the power cord is good. Replace if needed
3. Have the computers power supply checked. Replace if needed
4. Have the motherboard checked. Replace motherboard or get a new computer your choice.
Sep 09, 2009 | HP Compaq Presario SR2011WM PC Desktop
No power to motherboard Shuttle AN35n ultra
Hi there
Try One of the following steps:
  1. Flash Youre MB BIOS.
  2. make sure that CPU Fan is working OK.
  3. Is the CPU attached to the MB correctlly.
  4. Is the CPU Fan base and scrowse faremly scrowd and positioned on the MB.
  5. Chec MB in/pot power pins connections.
Hope That will Help.
May 16, 2009 | Shuttle AN35N Motherboard
EMachines not powering up
You may have updated windows to a point that this old machine cant handle the revamp. Kick back to an older ops system, although that poses security risks. Your motherboard may also have given up. Best advice - upgrade, and retire this machine to the recycle bin.
Jul 18, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
19 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
