Question about Moultrie 25 Gal. Deluxe Sprayer with 10' and 30' Boomless Sprayers
Northern sprayer blows fuse
Blows 7.5 amp fuse
Borrow ATV to do some field spraying but it keeps blowing the 30 amp fuse. Sprayer on its own power. Replace fuse, runs for a couple of minutes then blows, thoughts?
Check the rated amp draw on the sprayer. It might be rated higher.. If the sprayer is wired with too small wire it might be causing too high an amp draw..see if the wires are hot? How is the sprayer grounded? Make sure ALL the wire connections are clean and tight. Use a blade type fuse in a waterproof holder. Recheck all this and repost with the results.
May 28, 2017 | ATVs
No fire to #10 fuse which feeds the relay. when ignition is turned on this fuse blows and #7 blows when ignition is turned on
what devices are linked to fuse ten and seven ?
have you replaced the relays ?
has any electrical work been done recently ?
what is the amp /volt meter reading to both fuses as the ignition is
turned on ?
the vehicle model or type may help a little
Oct 24, 2014 | Cars & Trucks
Fuel pump fuse blows while under load. 1998 Jeep TJ 4.0 automatic Only blows while driving. F16 is the fuse. Traced all wires from pump, wiggled, jjiggled, squeezed and bent every wire, harness, plug......
Sounds like fuel pump worn and drawing more amps under loaf, find hot wire to pump and amp test. Shoul be between 7 to 17 amps any more and pump due to fail soon. Good luck.
Oct 06, 2014 | Cars & Trucks
Funai magnavox model#37md359b-7 when turned on for amp fuse blows on circuit board
Could be 100 things. Do you see any burnt components or burnt spots on the board? Probably no way for you to fix this unless you have the electronics repair skills unless you visually spot a short on the board like a loose screw that ended up laying on a couple of components etc.
Feb 18, 2013 | Funai Magnavox 19" Class 720p 60hz LED TV...
Brake light fuse keeps blowing in my 1997 Suburban only when towing trailers.
If the fuse blows on different trailers then it's all down to the vehicle. You either have incorrect wiring on the vehicle, a short OR the fuse is not of a high enough value to cope with the additional brake lights? You could try removing all the trailer bulbs EXCEPT the brake lights - e.g. if it's trying to power up the indicators too? That would stop the fuse blowing...... OR remove the brake bulbs from the vehicle & see if it operates the trailer without blowing...... Check the total wattage of ALL the brake lamps & see if the fuse is actually of a high enough rating? Be aware though that increasing the value of the fuse could cause damage elsewhere! As a rough guide a 25 watt bulb will pull around 2 amps at 12 volts - so 4 bulbs may pull up to 8 amps & clearly blow a 5 amp fuse! If in doubt take it to an auto electrician...... The wiring needs to be correctly protected!
Apr 02, 2017 | Cars & Trucks
A/C Gets cold when Idle, but blows warm/hot air when on Interstate
Check the #7 (10 amp) fuse iside the dash. If it is blown, replace it. If A/C starts working but blows fuse again, you have a wire with the insulation worn off. The white wire that comes down in front of the oil pan. Good luck!
Apr 21, 2010 | 2000 Dodge Neon
My Amana package system fan only blows cold air
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
Oct 20, 2009 | Amana PTH153B50AE Air Conditioner
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Sep 07, 2009 | Panasonic CT-32SX12 32" TV
Fimco Sprayer , 25 gallon, 2.1 gpm, 12 Volts - Blowing fuses
Soiunds like you either have one of two things. Either the pump motor is bad or you have a wire that is shorted out. look for chaffed or bare wires or burnt spots on the sprayer and the machine towing it. one of the two is your issue. Hope this helps!
Sep 19, 2008 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Moultrie 25 Gal. Deluxe Sprayer with 10' and 30' Boomless Sprayers Logo
Top Moultrie Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Moultrie Garden Expert? Answer questions, earn points and help others
