Question about ASUS Computers & Internet
Fc ce d33005 won't power on
Motherboard won't power on. replaced switch and tried jumper, still no power. little green light on MB is flickering and power cord is good. help
  • 624 Answers
SOURCE: Blinking Power LED ... no other action
Hi switchblade, Some of this will seem basic or even a rehash of what you?ve already done but please keep an open mind. The one thing I?ve learned over the years is never assume anything especially when things aren?t working like they?re supposed to. -The first thing I would do is to check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. It?s possible that whatever caused them to replace the motherboard could have been caused by a defective power supply or vice versa. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. -Try a more basic known good video card, a PCI if you have one. -Again whatever problem caused MSI to warranty replace your motherboard could have damaged your processor or memory. I would have expected a beep code but if you?ve gotten this far without resolving your problem we?re running out of possibilities. -If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Posted on Jan 08, 2007
nickstorm
  • 93 Answers
SOURCE: asus k7m motherboard connections
The jumpers are located in the lower right hand part of the MB. Here is the user manual (in PDF format), linked from the ASUS website. It has diagrams, and instructions on connecting those wires.
http://dlsvr03.asus.com/pub/ASUS/mb/slota/k7m/k7m-104.pdf
Cheers
Posted on Nov 14, 2008
Chinthakaj
  • 416 Answers
SOURCE: i want an audio driver for my computer, i lost the CD
saintgene has given you a good link
Posted on Jan 15, 2009
wahidmeer
  • 33 Answers
SOURCE: Compaq Evo D5 power light flashes red.
Check the power supply unit.
Posted on Aug 19, 2009
SOURCE: intel emachine t3828
Geeze, after working on hardware for 27 years i love the short circut dummie. Anyway yes, it's the motherboard / yes the green light will still come on on that model and quite a few other models. Dont worry about repairing / i.e. removing components on the motherboard, it's a fruitless endevor but a great way to waste time. A motherboard for that model will cost about 100-150 bucks / easy replacement. It's actually rare for both the power supply and mother board to go out on a tower/mini tower type system. Older laptops had that type of prob. Those emachines were **** for the mostet part. On the other hand Gateway has really gone up in quality and i have been quite impressed with them in the last few years...
Posted on Mar 26, 2010
Have dell Inspiron 546 minitower. Been acting up lately where it won't power up. The LED light on PSU below voltage switch is green. Light on MB is orange. No power or indication at all on front...
PSU's put out several different voltages if the 12Vs isn't working it won't power the motherboard. Some outputs may still be functioning therefore you may see some lights on and even some fans running. Replace the PSU.
Jun 29, 2013 | Computers & Internet
Pc not starting from pressing power on. Green LED for SB_PWR is on and when power switch pressed, fan & cool fan flicker momentarily but nothing happens. They do not spin. No LED light appears on front...
> PC had been suddenly powering off several times intermittently for a few days leading up to this state. Does this mean the PSU or Motherboard is at fault?
Yes, either CPU or PSU or motherboard are the likeliest culprits.
It's easier to try a different PSU than to try a different CPU or motherboard.
Nov 18, 2010 | ASUS K8N-E Motherboard
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Feb 02, 2010 | AOpen S651M (918EM10S50) Motherboard
Same problem - green "power" LED on the MB but no activity
This series of machines is known for this issue. You can get a replacement motherboard for your pc from a website at www.barebonekit.com they boards run from $35 to about $65 plus shipping. This is much cheaper than you can get them most other places. We order from them on a regular basis and have had no problems. I hope this helps, if so please rate the solution.
Thanks,
Buddy
Jun 17, 2009 | E-Machines T2893 PC Desktop
I just replace the power supply and still not working
If all the power cables are attached to the motherboard (normally about 2 different cables), then:
1) Rule out the switch: follow the small cables that come from the power switch to the motherboard...pull it off the motherboard and try using a paper clip to "short" the jumper pins that the switch was attached to. This simulates the power switch being pushed. If that doesn't work then.....
2) Motherboard may be bad
May 07, 2009 | Dell PowerEdge 2300 Server
Emachine T2890 won't power up. After reading some posts on this issue I went ahead and replaced the power supply, but the unit still won't power up. I am fairly certain that the old ps was fried since...
If you remove all the RAM fro the system and power it on, you should hear "Memory Error Beeps" if not, then it is usually Motherboard or CPU, for around $30.00 you can purchase a PCI POST code reader to try to pin the problem down further.
I am assuming from the post that all PCI cards (dial up modem especially) have been removed. Sounds like a bad MB or CPU, but if the video is integrated,( built on the motherboard, and not a seperate card, the memory is responsible for video also, and it maybe defective.
Feb 19, 2009 | Intel D845GVSR Motherboard
Emachine T2890 won't power up. New power supply.
move its bios jumpur on cofig mod and after some time post it its orignal post .it will ok ok Insha Allah
Asus k7m motherboard connections
Cheers
Nov 14, 2008 | ASUS AMD 751 Chipset K7M (K7M/500/WA)...
Dell Dimenion 3000
sounds like you need a new motherboard. Try to reset the bios with the jumper (or remove the battery and unplug it) and see if that does anything, if it doesn't start looking for a new mb.
Jun 04, 2008 | Dell (E210882) Motherboard
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
