Question about Panasonic KX-TGA660 DECT 6.0 Plus Digital Cordless Handset
Phone will not hold time, date is ok. need to re enter almost every day
Model kx-tga660
  • 8 Answers
SOURCE: How do I set the time and date?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following. 1. Push PROGRAM key 2. Dial "0" 3. Enter year (last 2 digits) 4. Enter month (01-12) 5. Enter day (01-31) 6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.) 7. Enter Hour (01-12) 8. Enter Minute (00-59) 9. Press 0 for AM 1 for PM 10. Press "AUTO DIAL/STORE" key 11. Push PROGRAM key to return to normal mode.
Posted on Sep 16, 2007
SOURCE: Date/time change
Press program
then 0
(this will then display current date and time - overtype as follows)
eg. for Friday 2nd November 2007 8:58 am you type the following
071102 (date backwards) [space] 5 (Friday is 5th day of week) [space] 0858 (time) [space] 0 (0 is am, 1 is pm)
Press the store button and then program button to exit the programming.
Posted on Nov 02, 2007
SOURCE: Panasonic KX-T7456 Corded Phone - Date & Time Display
The display on the phone ... to change back and forth between the date and time, and the extension information, press the "star" (or asterisk) key while the phone is on-hook, this will toggle the display back and forth.
Hope this helps, David B.
Posted on Mar 23, 2008
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Posted on Dec 17, 2008
cnavarro
  • 2460 Answers
SOURCE: KX-T7730 Time and Date
Walk up to the phone and don't touch anything but the * button. Keep pressing it and watch the display. Now you now the 3 states of the button.
Carl
Posted on Jun 19, 2009
Change time on KX-TG4713C
To change the time, pick up a handset with the phone in standby mode. Press the Menu button (the middle soft key below the LCD screen). Then press # 1 0 1 . If you need to change the date, type in the date in a two digit format for month day and year. Press OK (one of the soft keys) when done (or to skip changing the date). Enter the current time with two digits (12 hour time). Then use the arrows to select AM or PM. Press Save (again a soft key) and then press the Off key (to the lower right of the arrow keys).
Panasonic has the manual for the KX-TG4713C and related models here: http://www.panasonic.ae/en/manuals/kx-tg4711.pdf . See page 15 of this PDF.
I hope this helps.
(If your phone is set to French as the display language, you'll get the time in a 24-hour format. In that case, put in 1:30 pm as 13 30 . Then press Save and Off.)
May 04, 2016 | Lands Phones
Kx-tga660 drops calls
The main unit has a problem and the secondary unit only replicates the same problem. It is not the second phone.
Dropped calls can be from a bad connection from the source (wall plug) to the input port on the phone. Get a new wire and see if that helps with the problem.
Jul 29, 2014 | Panasonic Lands Phones
How can i set the date n time in Panasonic TX-TGA542AL cordless phone?
This is how to set date and time on panasonic KX-TGA542AL.
Press the "Menu" key.
Use the up and down arrow keys to select "Date and time." Press "OK."
Enter the month, date and year using two digits for each on the keypad.
Enter the hour and minute in 12-hour clock format using the keypad.
Press the asterisk (*) key to toggle between "AM" and "PM."
Press "OK" and then "OFF."
Regards
Jul 12, 2011 | Panasonic KX-TGA560 Cordless Expansion...
HOW DO i CHANGE TIME ON PANASONIC TELEPHONE KX-T7730
Press Program
0
you will see a display (January 19, 2011 - display 110119)
enter your date (don't press any other buttons, the phone will do in sequence)
YYMMDD
enter day of the week (1-Mon, 2-Tues, so on)
enter time (don't forget to enter 0 if like 9:30)
0930
enter AM or PM (0-AM, 1-PM)
0
then press store button
then press program button
you should see your date and time display
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
Need to know how to set the time/date on Panasonic KX=TG5100
To set the time, press the function/edit key, scroll to date and time by using the up and down arrow keysand press the foward arrow when you locate time and date.Enter in 2 digit values for the month day and year.enter in a 4 digit value for the time then select AM/PM by pressing the *key. press the down arrow to save and the stop key to exit.
Dec 22, 2009 | Panasonic KX-TG5100 Cordless Phone
How can I change the time on my KX-T7730 phone
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
password ( default is 1234).
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and congratualations - you are done.
Nov 17, 2009 | Panasonic KX-T7730 Corded Phone
Need to reset the time and day
From extension 101 or 100 (the main phone) press PROG dial **1234 000 and ENTER Change the date if you have to, if not, press NEXT. Dial the time as 4 digits and press ENTER on the Navigator key if the AM/PM is correct, then press HOLD EXIT.
Carl
Mar 10, 2009 | Panasonic KX-T7433B Corded Phone
Date & Time
Press PROGRAM + ** + User Programming Password (default is 1234)
Press 000
Press NEXT (Sp-phone button) : The date will be displayed.
To change the DATE (or you can press next again to go straight to change the TIME)
Enter the year (last 2 digits)
Press --> (FWD/DND button)
Keep pressing SELECT until the desired month is displayed
Enter the day
Keep pressing SELECT until the desired day of the week is displayed
Press STORE
To change the TIME
Press NEXT (Sp-phone button): The time will be displayed.
Enter the hour
Enter the minute
Press Select for AM or PM
Press Select for 12 or 24 clock hour
Press STORE (Auto Dial button)
Press END (Hold button) to exit
Jan 08, 2008 | Panasonic KX-T7431 Corded Phone
Panasonic KX-TGA660 DECT 6.0 Plus Digital Cordless Handset Logo
21 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
