Question about Refrigerators
Gaggenau error codes
F50
3 Suggested Answers
  • 414 Answers
SOURCE: we have an Gaggenau EB 290 oven and the error code
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
Posted on Jul 13, 2010
shreck1969
SOURCE: gaggenau over eb 270 error code f10
hello i m french f10 is a problemn of the temperature sonde that give gou the temperature of your gaggenau
Posted on Sep 04, 2012
Gaggenau over eb 270 error code f10
May 26, 2012 | Ovens
Gaggenau oven BO 270 error code E005
We have a Gaggenau BO250/251. It gave error code E005, and after a lot of frustration, we opened the left hand light (NOT the light at the top of the owen) and fiddled a little with the bulb. And voila, the owen worked again.
Stupid design to disable the owen when the light does not work. Bravo, Gaggenau....
May 19, 2012 | Gaggenau EB 270/271 Electric Single Oven
I am getting a F50 error during the rinse cycle - what does this mean?
here is what the F50 error code means and what must be checked when it comes up
F50
(F50)
Motor Stalled F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
Jul 30, 2011 | Kenmore 23822 Top Load Washer
Washer stops and gives f50 code
Hi, the F50 error code is a stalled motor error. There is a part called a "Rotor Position Sensor" that sees the motor running. This error will display if it faulty..
Sep 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
ERROR MESSAGE F50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&*(
Jun 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
We have an Gaggenau eb 290 oven and the error code F23 shows up - what does this mean? how can we fix it?
All the best.
May 13, 2010 | Gaggenau EB290 Electric Single Oven
Error code f50
The F50 error code is a stalled motor error. There is a part called a "Rotor Position Sensor" that sees the motor running. This error will display if it does not see motor movement during a cycle.This is a repair I recommend a technician do but there is one thing you can check.
You want to make sure that the spin basket turn freely. turn the basket by hand and it should turn freely. If it does not turn freely then it could cause the F50 error.
If the basket turns freely then the problem is most likely the main control or the Rotor Position Sensor has failed.
I recommend having a technician check this problem.
Mar 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
