Question about Magellan RoadMate 700 GPS Receiver
MAGELLEN ROADMATE 700 NO POWER
I have a Magellan Roadmate 700 and i have toruble getting it to pwer up. It will go on if you play around with the cord but if you hit a bump it just goes off again can you help me??
  • 3 Answers
One of the wires in your power cord could be broken. If you have the a/c adapter, see if you can power up with that. If you know someone else with a working Magellan, you could borrow his cord to test your unit.
If not, check the car adapter with a continuity tester. Put one tester probe on one of the side springs of the car plug and the other probe on the outside metal of the GPS plug. If that shows continuity, place one tester probe on the end tip of the car plug and the other inside the the GPS plug.
If either of those do not show continuity, first take apart the auto side of the cord. Check the fuse and the wire to contact solder joints. If they seem okay, carefully cut back the molded plastic from the GPS end and examine the wire to solder joints. If any are broken, replace the cord or resolder the joints.
Posted on Nov 08, 2007
How do i get an antenna for the magellan roadmate 700?
For an external antenna go here:
http://shop.ebay.com/items/magellan%20antenna?_dmd=2&_cpr=249&keyword=magellan+antenna&tt_encode=raw&crlp=1889499293_9406
Jan 01, 2009 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS does not work properly
It seems that Magellan is not good with the power connectors on their units, I believe the problem is with the power adapter plugged into the cradle. Sorry I have no information about a repair center. Usually for an absorbent amount of money, Magellan will repair.
Dec 23, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700
go to the magellan website and all your answers are there.
Sep 13, 2008 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Downloading new version 6 to my roadmate 700-760 gps
I had a very similar problem downloading the new version for my roadmate 700 as well. I chose to shut system down .I then unplugged everything. I reinstalled the dvd into my computer.I powered up the roadmate700 and hit the enter button and the screen came up to pick user I hit user one. I plugged the USB calble in and started the download again and it worked out for me just fine. I hope this works for you also. Good Luck
Dec 21, 2007 | Magellan RoadMate 700 GPS Receiver
The most obvious question is, have you accidentally turned down the volume to a level where it can't be heard. There is a volume wheel on the unit. Also, there is a way that the sound can disappear if the unit gets "locked up". But that shouldn't be a persistent problem. Removing the power cord and reinserting it should clear that problem.
Dec 09, 2007 | Magellan RoadMate 700 GPS Receiver
Road mate 700
The flash card hole is supposed to be empty - all you need should be on the hard disk BUT the first Roadmate 700 I purchased was empty i.e. no software loaded. The second failed due to bad power connection, the third worked but was factory refurbished! what a crass organisation Magellan is!!!
Try fiddling with the power connection that goes into the cradle that the unit sits on. The power connection is ultra sensitive. BUT, if you've only just bought the unit then you are in luck - return it and get your money - back Magellan Support is extremely poor.
I am binning my Roadmate and getting a Tomtom720 Go series with maps and cameras preloaded - it auto updates when it is on its cradle attached to my PC/internet.
Bin the Magella - 4 years of problems!!!!
Oct 24, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
110 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
