Question about Honeywell Programmable Thermostat Heater
New thermostat won't turn on cac
We recently had a new thermostat (honeywell) installed. But now that summer is here our CAC won't turn on. CAC worked fine before. How can we fix it without calling HVAC pro?
  • McGyver2 May 11, 2010
    Have you completed the programming?
SOURCE: honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Posted on Feb 07, 2008
  • 518 Answers
SOURCE: honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Posted on Mar 07, 2008
  • 233 Answers
SOURCE: I have a honeywell III chronotherm thermostat /It
it sounds like it is time to repalce the stat, auto is set to allow the fan to run only when the heat or a/c is on, the switch for heat and cool will select either, and the temperature lever should allow contact for the bulbs to bring on the desired component. there are no replaceable parts on a thermostat, or I would try to walk you through replaceing them. good luck.. I prefer the honeywell vision pro or the white rodgers 9500 series stats
Posted on Jul 14, 2009
heatman101
  • 43501 Answers
SOURCE: Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
Posted on Dec 28, 2009
SOURCE: honeywell thermostat
This is a long post, but I suggest you read the whole thing before doing anything.
1. Remove the face of the unit from the wall, then remove the plastic casing that covers the touch screen. It takes some force to remove it, and it will snap as you pull it off (sounds like it's breaking but it is not). Then remove the circuit board (with lcd attached) by moving the tabs on the left and right outwards at the same time (you can see where the tabs are securing the screen in the casing).
2. Near the top there are too small ribbon cables that plug into the circuit board. They are fragile, so be careful with them. On the board, you can see the connectors marked for touch screen and lcd. One for each cable. There are two small tabs on either side of the cable. Pull up slightly on the tabs at the same time and they will slide up only 1/8 of an inch or less (very small amount).
3. Carefully slide the cable out (upwards, if you were looking at the touch screen) and then slide it back in to ensure it is fully seated. Again, be careful with these cables, as they are fragile. If your touch screen does not work, then you should only have to reseat the touch screen cable. Reseat the lcd only if there is a problem with the visual display.
4. Insert the lcd screen back into the casing by pushing it straight in (there is a small hole in the lower left corner that matches with the casing). Reattach the plastic cover by snapping it back on (should go back on with some force if you line it up correctly). Finally, reattach the entire face of the unit to the wall (make sure you line this up as well, the pins have to be inserted correctly to avoid breaking them).
If everything works now, then you are back in business. If not, you probably broke your touch screen.
Posted on Dec 11, 2010
Wat power supply is compatibe wit a cooler master cac-t05-uw
It all depends on the equipment you intend to put in the case to meet your power requirements.
Sep 04, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Power supply compatible with CAC-T05-UW
It uses standard ATX power supplies, get the best you can afford . Just make sure it has enough power for the components you are going to put in this case.
Aug 04, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Compatibility
All of the new style power supplys have all of the adapters you will need
Jun 27, 2010 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Cac is readable by reader but is not permitting its use
ActiveCard Gold had known problems that were never fixed. Upgrade to the newer Active client 6.2 very reliable and stable CAC program. Also has several very useful tools in it as well. DoD switched to this a few years ago and has worked very well.
May 21, 2010 | ActivCard Gold 2.2 for CAC (gacg22cl)
How much is the usb, firewire, and audio ports model cooler master cac-to5-uw?
Should only be about $5-$10. You can get it directly from Cooler Master.
http://cmstore.coolermaster-usa.com/product_info.php?cPath=18_25&products_id=199
Jan 13, 2010 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Need a power supply for the cooler master CAC-T05-UW
I've used Cooler Master, Rosewill, Antec without fail. Warranty 2+yrs, power efficiencies >75%.
Jan 07, 2010 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Brand and model number of CAC-TO5-UW and its cost
Cooler Master Centurion 5, CAC-TO5-UW, Black w/Silver Trims ATX Mid Tower, W/O window, W/O PSU - Brand New $35-$55
Dec 10, 2009 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
HP 9250c Digital Sender
The CC543A is the approved CAC reader from HP. That is what we are using on these devices throughout our organization. The reason some CAC readers do not work is because the STIGS on the device from HP require that the device software for the readers also be used. The readers are about $300 each.
Apr 13, 2009 | HP Digital Sender 9250c scanner Printer
BRAND,MODEL NUMBER,AND COST OF COOLER MASTER CAC-T05-UW
The CAC-T05-UW cost between $35-$55 depending where you buy it from.
Feb 23, 2009 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Heating & Cooling Logo
91 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
