Question about Schlage Locks & Locksmithing
Schlage door lock random disable - Schlage Locks & Locksmithing
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Door will unlock without entering code
"Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? "
Feb 15, 2012 | Schlage BE365-PLY BE365PLY626 Satin...
Schlage deadbolt
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
You also need to check the operation with the door open versus the door closed--to make sure that you haven't developed a mechanical bind between the door and doorjamb. If all else fails, the lock should be under warranty!
Jan 26, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Can't push one button to lock anymore
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.
To enable/disable this feature, enter your Programming Code --press Schlage button--press 7
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck-and please provide feedback if this helps!
Aug 12, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Scroll down and find them under the heading Electronic Security-Keypad Deadbolt BE365
Aug 11, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
Schlage camelot key pad does not engage exterior locking knob when you press the schlage button. I have tried three different locks.
Here is a link to the installation instructions:
It sounds like you may have the Turn Lock Feature disabled. View and scroll down in the instruction sheet to the Troubleshooting portion, where it says " Pressing (the) Schlage (button) does not rotate deadbolt" The solution is to push the PC button, then the Schlage button, then 7 to enable the turn lock feature.
Here is the contact info you need for customer service:
Olathe, KS 66061
May 02, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Door has worked fine for years with a Schalge camelot electronic lock. Tonight it stopped working and you could not open the door with the inside or the outside handle. Key would not open door either. I...
Olathe, KS 66061
Apr 16, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
When we lock the door you just have to press the schlage lever on the top of the elecronic keypad and the door opens. Help we don't want to go to bed with the house unlocked
the lock is set in factory mode and needs to be programed to the security code that you choose.
go through the code set up and program in your code and the lock will work as intended.
if there is a problem with the lock and it will not accept the codes then the only way to disable the motor function of the lock is to remove the battery itself and use the key bypass until you can get the lock fixed or replaced.
c...
Jan 21, 2011 | Schlage Lock BE365VCAM716 Electronic...
Hi does this lock auto lock like the one with a handel does?
To enable/disable this feature, enter your Programming Code--press the Schlage butt0n--Press 7.
Nov 23, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
I press the schlage button i can unlock the door by turning the button
Scroll down and find them under the heading Electronic Security... 365
Good luck--and please provide feedback if this helps!
Nov 06, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
Locks & Locksmithing Logo
29 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
