Question about IBM Computers & Internet
Synchronizing boot order - IBM Computers & Internet
  • tony wahlman
    tony wahlman Aug 18, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
OK, i got a new wii remote, set it up, and now none of my wii remotes are working including the one i just set up.
Try these two synchronization processes and if it still doesn't work than contact me:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This procedure must be followed for each additional Wii Remote added to your system.
    One Time Mode Synchronization
Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  1. Select the Wii Remote Settings option from the Home Button menu.
  2. Select the Reconnect Option.
  3. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
PCHELPSTER007 from youtube. If I helped you than please rate me up and if you have any other problems please feel free to contact. Thank you.
Jul 06, 2011 | Video Game Consoles & Games
I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Set Up and Use of the Nunchuk
  1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
  2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
  4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
May 04, 2011 | Toys
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Jan 27, 2011 | Nintendo Wii Console
MY 1984 GL1200 HONDA .NEED TO KNOW WHAT ORDER I STHE CARBS IN LIKE #1 #2 #3 #4. WHICH CARB IS THE ONE TO SYNCHRONIZE TO. THANKS.
The right side rear carburetor has no adjustment. Keep adjusting your idle to 1000 pm. Synchronize the to right carburetors to each other. Synchronize the two left carburetors to each other . Then synchronize the left bank to the right bank. You may have to do it more than once. Be sure to keep adjusting the idle back to 1000 rpm.
Oct 08, 2010 | 1984 Honda GL 1200 Gold Wing
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Sep 22, 2009 | Nintendo Wii Console
We have been playing gutar hero band and now our remotes only work on side how do i fix
  2. Select the Wii Remote Settings option from the Home Button menu.
  3. Select the Reconnect Option.
    1. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
  • this may reset the remotes for you
    info from nintendos customer service
    Jan 01, 2009 | Nintendo Wii Console
    Sync fails with "too many open databases"
    This is what I did to fix that error:
    Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
    After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
    Sep 07, 2005 | Palm Tungsten T3 Handheld
    Computers & Internet Logo
    56 people viewed this question
    Top IBM Computers & Internet Experts
    Computer Links
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
