Question about Maytag LAT3600A Top Load Washer
Washer is "dead." Was stopped after fill up, and now no power.
Maytag washer (model LAT8506AAE) filled with water, began washing. We opened lid to add more clothes and when we closed it, it is as if there was no power. Checked circuit breakers they are fine, tried plugging it into the dryer plug, and still "dead." The timer is not making any clicking noise at all. Is there a way to test the timer, and/or the push button switch that is triggered when you open the lid?
  • gmfltchr Jun 20, 2009
    The wires on the lid switch are white (2), black (1), Green (1) and yellow (2). To jump the switch in an attempt to see if it is bad, which wires would I connect?
    President:
  • 1,136 Answers
Hi, I would check the lid switch first. Remove the two screws that hold the control panel to the cabinet and let it rest on the hinges. Locate the lid switch connection and either test it for continuity or use an insolates wire and jump the switch by inserting the wire into the gray and brown wires. Turn the washer on and see if it works.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
Posted on Jun 20, 2009
  • Victor
    Victor Jun 20, 2009
    Hi, The diagram I looked upp show to jump the white and yellow wires.
    If you haave a meter, you should unplug the wires and test the switch for continuity. With the lid closed, there should be continuity between the post that the wite and yellow wire connect to.
    Vic
  • 1,305 Answers
Try pushing firmly on the center of the lid.... with the lid closed... it could be that the lid switch isn't making proper contact to turn the machine on.
If this is the case, you can open the lid, and while holding the lid open with one hand, put firm pressure on the rear lip of the lid right in the center..where it makes contact with switch...
This was a common occurence at my laundromats because people would sit/stand on the machines..
Hope this gets ya up and runnin'
    Sergeant:
    Champion:
  • 266 Answers
Its probably the safety switch under lid just replace it its like 20 dollars with a meter u can test the timer but u need to know how
  • tragedy lok
    tragedy lok Jun 21, 2009
    white and yellow, do u have a meter?
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
May 18, 2011 | Maytag Bravos MTW6600T Top Load Washer
Washer is full of water and completely dead...
the maytag atalntis is a great machine but often falls victim to the lid switch problem
try pushing in the lid switch, right in the middle on top of the lid
you will se a lil plunger, push it in
AP4008646
goto appliancepartspro.com
runs aound 20.00 but im sure thats your issue
Oct 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Washer will not fill with water
Check the lid switch...this controls all power to the machine and if the lid isn't closed, it can interrupt the water fill even with the lid appearing to be closed. Press firmly on the center of the lid when it's closed. Sometimes the lids on these maytags get tweaked a little and then don't allow full contact with the switch... Let me know ..
KEN
May 10, 2009 | Maytag Dependable Care LAT9206
Maytag Washer Just Stopped After it Filled With Water (Timer?)
Cant rule out the timer but I suspect first check the lid switch. The timer and other components are fed from the lid switch on most models. Just put the2 wires together and reapply power if it works replace the lid switch. If not you'll have to have a wire diagram to know where to check next, but your water level switch "fill switch" could be at fault. it stops the water valve 1 way and can energize the rest of the circuits the other way. It may not be closing in the "full" direction. Again this switch if so wired will have 3 wires on it.
Mar 24, 2009 | Maytag Washing Machines
Top loading Maytag washer Model #A9700 washer fills with water then stops, no washing, no spinning
When the machine worked would the machine stop in the wash cycle when you lift the lid? If so you might check your lid switch.
Jul 16, 2008 | Maytag Washing Machines
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag LAT3600A Top Load Washer Logo
492 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
