Question about Evercool EVERFLOW 60X60X25mm Dual Ball Bearing PWM Fan F126025BU
Evercool EVERFLOW 60X60X25mm Dual Ball Bearing PWM Fan F126025BU\
I want to use the fan for another application than intended. I need a schematic showing function of each of the 4 wires black red yellow blue
The color code of PWM fans is standard.
Black is ground (return)
Red is +12 Volts
Yellow is the fan speed signal
Blue is the Pulse Width Modulation signal
An important thing to remember when adapting a case fan to a different application is,
the sleeve bearing fans are not rated for continuous operation.
For continuous operation, only the ball bearing fans such as the Arctic Cooling fans of the CO series should be used in a continuous duty application.
Sep 15, 2015 | Imicro CA-FAN80PW 80mm Sleeve Bearing PWM...
I have an acer aspire x1301 and was wondering if you can connect any cooling fans
You can put cooling fans on anything. It looks like you can put a fan on the back, its looks to be a 80 or 92mm fan. I recommend a dual ball bearing fan if you go that route since they last longer. You can also put one on the side, if you cut a hole for one on the side. Another good option would be to upgrade the cooling for the processor with something that is all copper, and use artic silver 5 as the thermal paste.
Sep 11, 2013 | Acer Aspire T135 PC Desktop
Everflow Model R126010BU fan failure
the coil for fan, can be reheating for the years and fluctiuation of voltage in line. Will be a GOOD idea to replace with the properly parts from factory or similar.Remember see the tech spec. like 115vca or 220vac OR 60HZS, watts.God bless you5e456c2a-fffd-4c17-b0d3-97799433e6cf.gif
Apr 02, 2013 | Microwave Ovens
I am in need of a fan motor for my Danby Frig. Paret #JG50.DQ-10. Cannot find it anywhere. Suggestions?
The problem with the factory fan is that it is a sleeve-bearing fan. On average, a fan should operate for about 50,000 hours, which if it runs continuously would be over five years. However when the operating temperature rises or the fan is installed "not exactly" vertically, it will have shorter life.
I had to replace my fan two times withing two years since we bought the unit! Plus the stock fan becomes quite noisy after a couple of months of work.
With all of these problems I did some research for better fans and decided to purchase a ball-bearing fan to install it into the cooler by myself.
Ball-bearing fans on average outlast sleeve-bearing fans by 50 percent and produce less noise.
It's very important to purchase the right AC 115 Volts fan for this Danby wine cooler.
The original fan is Rullian Science RAL 1225S2 (120x120x25 mm in size, 100-125V AC, 0.09A)
The replacement model is Orion OA12AP-11-3TB which I got for $16.75 from Mouser Electronics (mouser.com). The replacement model is ball-bearing cooling fan with slightly higher/better parameters, which will help to cool down the wine cooler coil faster.
To replace the fan you need to tilt the wine cooler on the side and unscrew two small screws at the bottom that keep the original fan in place, remove one screw to the black box where the fan wires are attached and unplug these wires. Then you just need to replace it with the new fan and test that it works properly. If you never used Soldering Tool before you probably will be better off with getting some help from certified electrician - it still will be less expensive than getting this fan ordered every year from Danby.
Nov 06, 2012 | Danby DWC513BLS Wine Cooler
My emachine t1090 is making extremely loud whineing noises( like my bathroom fan when it is dirty). I took the casing off of the machine and cleaned it with compressed air, alos took casing off of the fan...
you have a ball bearing fan, after awhile, the fans ball bearing move around, thats were you are hearing the whining noises. All you have to do is replace the fan with the high piched sound.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150007
The fan is $2.99USD and $1.99USD Shipping, no tax. Fan Total = $4.98USD
Have a nice day
Aug 26, 2011 | E-Machines T1090 PC Desktop
Need new internal fan.
Well meaure it in mm or in inchs, then convert it to mm. Then buy the fan off of newegg.com just make sure you get a two ball bearing fan because they last allot longer.
Apr 24, 2010 | Systemax Venture H356 Desktop Computer -...
NOISY FAN ON CASSETTE UNIT
Probably Ball Bearing Problem Replace Axial Fan Motor Ball Bearing Will be ok Almost Done
Good luck
Oct 13, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Ball Bearing
On what are you wanting help with. If this is a vac, what is brand and model number???
Mar 18, 2008 | Vacuums
Evercool EVERFLOW 60X60X25mm Dual Ball Bearing PWM Fan F126025BU Logo
27 people viewed this question
Top Evercool Computers & Internet Experts
David Payne
David Payne
Are you an Evercool Computer and Internet Expert? Answer questions, earn points and help others
