Question about Samsung LN Televison & Video
WHEN YOU POWER ON TV, IT WILL AUTOMATICALLY POWER OFF AND ON NUMEROUS TIMES BEFORE IT WILL STAY ON
Tv will not turn on unless it is unplugged numerous times and will not stay on unless it has a program at all times? If not, it goes to standby and shuts off 42HDT50M Hitachi
There are components on the power supply board that are failing. www.shopjimmy.com has a wide array if service parts kits that contain the most often failed components. Prices are good. These are for do it yourselfers, so if you are uncomfortable with a soldering gun, then have a repair shop do it. After 11 years, though , it may be time for a new one.
Jan 24, 2014 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
When I turn on my HL-T5687S, the screen remains black and there are 3 dots on the lower right hand side of the panel?
My TV is (same model is doing the same thing). The manual shows that the 3 blinking lights indicate "LED may be defective. Please contact a certified technician."
Note: When I power my TV off (unplug) and back on, the TV's left indicator light is solid for less than a second ("Stadby state") then the right light blinks ("The picture will automatically appear in about 15 seconds") for about 15 seconds. This pattern is repeated numerous times (I think it was 5 times). I believe the TV must be failing some power-on test. Aftere failing 5 times it gives LED may be defective indication.
Nov 09, 2010 | Samsung HL-T5687S Television
Tv does not stay on red light blinks 9 times
Power supply board it dead,replaced this board will get ur power back.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 09, 2010 | Sony QUALIA 005 46 in. LCD Television
Will not turn on and stay on
May be its Faulty transformer is making Noise,Please check the model number of yout TV and check for Warranty ...Contact customer support for replacement or service(click here)
Hope this info is useful for you..
May 31, 2009 | Hitachi Televison & Video
Power wont stay on, switches automatically off.
replace the power suply unit the 5v stand by is not working
if youhave good hands buy a 5 volt power supply and connect it to the same output (but remember to remove the transformer for that power )
check it with a dvm
hope i helped
Mar 12, 2009 | Televison & Video
Motorola H700 will not connect or stay connected
hello, dont be dispaired just keep trying to connect by pulling your mike in and out, some times they need to be worn in, had same problem with my first h-700 and after about 20 0r 30 times moving the mike in and out it took off, some of my seven h-700s paired automatically and some didnt, the secret to putting them in discover mode is with the mike closed press the call button till it turns solid purple and briskly pull the mike down and go thru the pairing process.these are my expieriances, may not be a solution but give er a whirl. good luck m,m.
Jan 21, 2009 | Motorola Mobility H700 Wireless Headset
Turn on and stay on
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Nov 06, 2008 | Televison & Video
Turns on an off by its self
In order to fix it yourself you will need a digital VOM meter (preferably one that can test diodes) a 25 watt soldering iron desoldering wick and a cap analyzer. Otherwise you should take it to a shop.
Aug 17, 2007 | GE 32GT660 32" TV
Televison & Video Logo
Henry  Thomas
Henry Thomas
