Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Weed eater starts, won't stay running. Have replaced fuel lines, cleaned carb, cleaned screen in the carb, and followed pretty much all other suggestions on line. Fuel line has bubbles in it, but is not leaking from anywhere. Any suggestions for finding the culprit and/or moving ahead to fix problem.
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
  • 7 Answers
SOURCE: 25cc weed eater, will only idle
double check your carb as it should have a screw for the fuel mixture. some carbs have a plastic piece over them that only lets you move the screws so far if you need more extreme adjustment they pull out about a 1/8th of a inch then you can turn in then push it back in, same principals as making a flame on a bic lighter bigger, if you cant find it take some pics of your carb and email them to me @ prerunnerrngr@yahoo.com and i will point them out
Posted on Jul 14, 2009
  • 130 Answers
SOURCE: Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
Posted on Jul 25, 2009
SOURCE: Fuel line size for troy built TB20CS weed eater
You probably have found the solution by now I would assume... TB won't tell you this because they want you to buy their stuff..
You probably are looking at the 0.08" diameter that's just a bit smaller than the 3/32". Hope this helps....
Posted on Apr 09, 2010
  • 78 Answers
SOURCE: replaced primer bulb and all fuel lines still
The primer bulb pulls fuel from bottom of fuel tank,when bulb is full it will return fuel back into tank,the hose entering bulb runs in the tank to bottom with filter on the end,the return hose stops just as it enters the tank maybe 3/4",make sure the hoses entering tank are tight fit or they will pull air in and leak.the carb may also need rebuild/clean,there is a screen inside of carb that may be stopped up which will need to be replaced.(carb kit).
Posted on Feb 18, 2011
Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
change the fuel lines over on the carby
you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
Mar 12, 2017 | Garden
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
John Deere weed eater problems
remove the muffler and run it if it runs good after that open the muffler and clean the screen inside
Apr 01, 2012 | Garden
I have a weed eater mod. 2816 and it will not run without having the choke on half open.
This is fuel starvation, remove and replace the the fuel filter in the tank, check the fuel line up to the carb for leaks, if no better it will need the carb off and clean/replace internall fuel screen and, or diaphrams.
Apr 20, 2011 | Garden
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
I have a weed eater trimmer that i replaced the gas lines but now when i pump the top of the carborator no gas gets to the carborator and the trimmer will not start.
REVERSE THE TWO FUEL LINES .. OTHER THINGS TO LOOK FORCHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
New fuel lines, wont stay run, swapt in/out line, wont stay run
Sometimes simply removing the carb and placing it in a carb dip will clean it without tearing it apart, also check or replace the spark plug. Make sure you have compression, good spark, and that fuel is getting to the carb. If that doesnt work, email me and I'll find you a diagram. Jblee1975@yahoo.com
Jul 11, 2009 | Craftsman 25cc Gas Line Trimmer
Won't stay running
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
Jim
Jun 25, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
