Question about SanDisk Sansa e250 MP3 Player
Reformatted sansa e250 need help
I have the same problem. I was trying to delete music files from my sansa E250. Nothing was working so I tried fomat. Now everything is gone. Any solutions?
When you format it, it deletes everything on the player. You'll just have to put everything back on it.
Posted on Jun 22, 2009
Sansa e250 2GB no work duplicate the song
Edit the ID3 tag of the files in full before reloading them to your player.
Sep 04, 2008 | SanDisk Sansa e250 MP3 Player
Deleting unresponsive files
try to get your computer to give it a drive letter go to my computer find the device right click then format. ti shoud format
at the same format by defult.
Aug 04, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e250r - cannot delete mp3 files
I have had this problem for some time now and finally got through to tech support for Sansa and now have the solution:Worked for both 230 and 240.
Take out the battery in the Sansa player; Put on lock on back side of Sansa player; Connect Sansa to the computer, Once computer recognizes device cancel out of that media program; Go to my computer on desk top; Right click on recognized Sansa device; Click format; Click ok to delete files.
Jan 13, 2008 | SanDisk Sansa e200 MP3 Player
I accidentaly sinc music to my sansa e250 from windows media player and it wont come off!!!
Mp3 files can be loaded using either WMP or Windows file manager (Explorer) but a different USB setting is required by each. WMP uses the MTP setting while Explorer uses MSC. If you used the wrong setting this may have caused your problem. Also for some reason MP3 files loaded using a file manager will not appear when trying to view them using WMP. To solve the issue I used the MSC setting to view all of my MP3's using file manager. I then deleted the ones I had recently added, changed the setting back to MTP and reloaded them using WMP. Worked like a charm. Hope that helps.
Aug 13, 2007 | SanDisk Sansa e250 MP3 Player
Empty folder
There may be possible reasons why your Sansa E250 would display an message on the LCD even when you've downloaded files to it: (1) The music file type is not supported by the player. Sansa players support only MP3 and WMA files. To determine what file type your have, right click on the file type and it should display the "properties" dialog box. Check if it is MP3 or WMA. For example, iTunes music files will not work with the player, nor will WAV or MIDI files. (2) Your music files are supported but the bit rate is not within the range that the player supports. Sansa players support MP3 files up to 128 KBPS and WMA files up to 64 KBPS. You may need to use a 3rd party music file editor to convert the files to a supported bit rate (3) You may have saved your music files in a folder and copied the folder to the player. Your Sansa E250 will not recognize folders. Either save them in the root directory or inside the "Music" folder -- your player's default folder for music files. Hope this info helps :)
Apr 12, 2007 | SanDisk Sansa e250 MP3 Player
My sansa wont work HELP PLZ
Ok, I have a Sansa e250 2.0 BG. I have an extra memory card but w/e thats not part of the problem. So, when I downloaded music, I accidently put more music on the Sansa memory and it made it too full. So now it has to do a system restart everytime I turn it on. Which is really annoying. And then I tried to delete some music so It would stop doing that and I could update it, But it shows up on my computer as there being no music. So theres nothing to delete! But it says the memory is full! HELP!!!!
Mar 22, 2007 | SanDisk Sansa e250 MP3 Player
Deleting files from Sansa e250
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Feb 18, 2007 | SanDisk Sansa e250 MP3 Player
Problem with deleting music
It might have reformatted the songs by accident. Just try to redounload the songs you want and dont download the ones that you wanted to delete in the first place. This happens a lot with Sandisk e250 mP3 players
Jan 02, 2007 | SanDisk Sansa e130 MP3 Player
Sansa e250
you will have to go to the srichtonize thing nd right click on music and press delete then it will help you
Sep 30, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
162 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
