Question about Sony Audio Players & Recorders
Cd player fails to play on cdpm42 player - Sony Audio Players & Recorders
MY DVD NOT PLAYING DVD MOVIES BUT PLAY AUDIO
The laser pickup assembly will often play CD's but will not play DVD's this is a sign the assembly is failing, far cheaper to replace the player.
Mar 10, 2012 | GPX D1816 DVD Player
When I load a cd in my Stanton C324 it reads "No
Hello
Clean your CDs before and after playing them. Although the compact disc has a much longer lifespan than does something like a cassette tape, it can be more fragile. Scratches, dust or other damage to the data side of the CD will cause many CD players to fail to read the CD or cause the CD to skip.
Examine the type and format of the compact disc if your CD player fails to read it. Verify that your CD player can read the type of CD and the files contained on it. Just because you've burned a collection of songs to a CD, for example, doesn't mean that your CD player will be able to recognize that information. You must burn CDs in a specially formatted "Audio CD" mode to play them on a CD player, or your CD player must be able to recognize the MP3 file format. Some CD players have limitations on the type of CD they can read. Verify that your CD player can read CD-R, CD+R, CD-RW or CD+RW compact discs.
Update your CD player's driver, if your CD player is a drive connected to your computer. Click "Start" and select "Control Panel." Click on "Hardware and Sound" and select "Device Manager" under "Devices and Printers." Right-click the icon for your CD drive and select "Update driver software." This may solve any issues the drive was having with playing CDs.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Stanton C324 Mp3 Cd Player With Effects...
Magnavox AZ9855 mini system (7 CD changer), trying to play a cd, the system ejects the CD and message Failed CD is shown. No CD will play.
Hi,when a system eject a CD and with a message "failed CD" It caused by the CD mechanisms that allows the CD to play to damaged that's why the CD keeps on rejecting the CD's being inserted into the CD player.
When you replace the CD mechanism that allow CD to play, problem solved.
Take care.
Oct 06, 2010 | Audio Players & Recorders
When I Play Music through Winamp/Media Player it
That is unusual - pressing in case should not effect play - not like a tape drive would.
Are you playing from CD or Hard-drive?
If Cd - try copy music to hard-drive and see how it plays - if ok - then something may be rubbing on CD in CD-Player? But that would give read errors. Have to remove CD Player and clean it.
Jan 29, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Plays some cd and not others
Perhaps I can help. Have you cleaned the CD's that won't play? That is the easiest thing to try first. Sometimes, however, when the CD player begins to fail, it will be selective in what CDs it will read. I can help you troubleshoot over the phone and/or repair or replace you CD player. Rod Stebelton, tech@wurlitzer-ohio.com.
Jan 01, 2010 | Wurlitzer Jukebox 1015 One More Time...
Player will not play cd - it reads then says
Your CD player is failed. It will need to be replaced. Some folks can repair but it cost less to have it replaced. If no one local will do it BOSE will for about $150.
Jul 11, 2009 | Bose Acoustic Wave music system II -...
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
Displays "NO DISK"
The message indicates that the system failed to read the index portion of the disc. Try cleaning the lens using a cotton swab and alcohol. Try playing a music CD as well. If hte CD plays but the DVD continues to fail, you have a failing optics assembly that needs to be replaced. This is the most common symptom of failing optics. DVDs will fail while CDs will play.
Keep us posted.
Dan
May 29, 2008 | Apex Digital ADV3800 DVD Player/VCR
Cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Nov 21, 2007 | Audio Players & Recorders
CD Player not playing any audio CDs
The laser is damaged or dirty. Try gently swabbing the lens with rubbing alcohol and drying with canned air. If this fails the laser is damaged and unrepairable.
Sep 12, 2007 | Jwin JX-CD780 Personal CD Player
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
