Question about Winter Sports
Torque specs 2003 arctic cat zr 900 - Winter Sports
  • 52 Answers
SOURCE: Torque Spec
78 inch pounds
Posted on Nov 21, 2009
nova2nv
  • 197 Answers
SOURCE: need to replace my stator on 99 zr arctic cat
Remove rewind then flywheel.Lower rewind housing bolt may be a little tough to get out being its on the bottom.Flywheel needs to removed with standard 3-bolt puller and may make a load pop when comes loose.Housing around stator needs to be removed,4 allen bolts hold this in place.Do not install flywheel until stator housing is bolted back in place.After you removed everything be sure to check and see if hood harness was routed under rewind housing because in the past a few had the wires smashed from engine pinching wires between stator housing and main frame.Best place to buy stator from is Dennis Kirk,$213,just did one on my 99 ZL600.
Posted on Jan 16, 2010
Testimonial: "thanx for the advice.Happy trails"
nova2nv
  • 197 Answers
SOURCE: I have a 96 arctic cat zr 580 efi that runs good
Remove handle bar cover,find 3 wires that come out of the right side throttle,follow them down to where they get just about under the cowling and disconnect them there.Find a wire to jump the 2 outside wires of connector and plug harness back together.This will disable your throttle saftey switch which is most likely the cause of your problem.The center wire is for the kill button on top of bars.
Posted on Jan 23, 2010
heimlich
  • 1978 Answers
SOURCE: 94 arctic cat jag 440 engine torque spec
Head torque is 18 to 20 ft lbs
Posted on Jan 16, 2011
nutznboltz08
  • 36 Answers
SOURCE: carburater schematics diagram for a 2004 arctic cat 300
Go to http://www.arcticcatpartshouse.com/arctic-cat-atv-parts.aspx?aribrand=ARC#/Arctic_Cat/2004_ATV_300_4X4_GREEN_MRP_%28A2004ATF4AUSS%29/CARBURETOR/A2004ATF4AUSS/A2004ATF4AUSR.
Posted on Oct 13, 2012
How to adjust the ride height on a 2015 zr6000
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Arctic Cat but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2015+arctic+cat+zr+6000+el+tigre+es
Oct 02, 2014 | 2014 Arctic Cat ZR 6000 El Tigre ES
On my 2014 eltigre6000 the engine with have a slight hesitation just after slowly taking off! It does it at first warm up and after bar,gas stop,etc!!!!
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Inlet system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
12. The enricher valve not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2014+arctic+cat+zr+6000+el+tigre+es
Mar 02, 2014 | 2014 Arctic Cat ZR 6000 El Tigre ES
Wont start spark but wont fire
Hi, Fireman1x I am sorry you can't find the first and best tool you ever bought for your Arctic Cat but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2014+arctic+cat+zr+8000+lxr
Feb 16, 2014 | 2014 Arctic Cat ZR 8000 LXR
2003 Honda CB 900 Hornet cylinder head torque specs
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.fireblades.org/forums/honda-fireblade/5000-98-900-torque-specs.html
Head bolt torque specs CBR Forum Enthusiast forums for Honda CBR Owners
Honda CB900F Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB900F Owner Manual
Jun 06, 2012 | 2003 Honda CB 900 Hornet
Arctic Cat snowmobile 2003 mountain cat 900, I just replaced
This repair manual is only a 2002, but it should suffice. It is 156 mb and in pdf form (a freebie):
http://www.carlsalter.com/aaman/Arctic_Cat_2002%20Service%20Manual.pdf ,
And the best of luck
Feb 03, 2010 | 2003 Suzuki LS 650 Savage
Need dry clutch torque specs for a ducati monster s4
The torque spec for a chutch nut on a 900 is 180-190Nm (136 ft. lb.) The torque spec for the clutch housing bolts (presure plate) is 30-34 Nm (23 ft. lb.)
Jun 24, 2009 | 2003 Ducati Monster S4
Winter Sports Logo
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
