Question about Rancho 2001 Dodge Ram - 2500, 4WD, with 8800 GVW, with dual shocks, without snow plow package - RS5000 Shocks
Fueel lift pump
Wont accelerate at first. then takes off after a few minutes
My 2005 volvo xc90 it shows codes P0027 P2401 and P2419 what parts i need to replace?
Appears you have a bad leak detection pump for the fueel tank system.
Oct 09, 2015 | 2005 Volvo XC90
Harley wont start with choke on,but can start it with choke off
Hi Cully, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
Jun 03, 2012 | 2001 Harley Davidson XL 1200 C Sportster...
Engine turns over but wont start fueel pump works change fuel filter
Check the spark. If there is no spark could be module in under distributor cap rotor some times moister and frost kills them. Check the coil after that if those are all-right check the computer.
Jan 28, 2011 | 2000 Chevrolet Silverado 1500
D3500 dually diesel has rough running problems for about ten minutes. Then runs great. Smoke is blue/white at first and truck wont run over 1800 rpm for ten minutes; then runs fine. I am told that it is...
I would look more at your injector pump than the lift pump....Dodge does have a problem with there fuel delivery ( not enough consistent PSI ) which in turn takes out the injector pump mainly because the pump has be running to lean...So look at replacing your delivery pump with something 14PSI or greater, unfortunately sounds as though you will have to get your injector pump either replaced or rebuilt
Dec 31, 2010 | 2002 Dodge Ram 3500 Truck
I have a chevrolet dmax/diesel 2005 and it won't accelerate at all. it was fine until a few days ago when I was driving and it suddenly stopped accelerating. so now I can go up to 30 mph and that's it.......
When My Dodge Cummins Diesel did that it turned out to be the fuel lift pump. That truck had 2 fuel pumps. Not sure about the Chevy, but it sounds like the exact same symptoms.
Dec 27, 2010 | Chevrolet 1500 Cars & Trucks
How do you take off fuel filter?
Just a thought. When you turn on the ignition, do you hear the fuel pump? If not, your problem, including acceleration, could be pump going bad.
Jul 17, 2010 | 1996 Chevrolet Blazer
02 Chevy Blazerstalling problem after about 45 minutes of driving
vacuum leak? or try the fuel pressure regulator my started stalling then got to where it wouldn't crank. changed the fuel pressure regulator and it ran as if it was brand new
Oct 09, 2009 | 2002 Chevrolet Blazer
Starting problem
check for fault codes in both engine controllers..may have a camshaft or crankshaft position sensor fault
May 10, 2009 | 1999 Dodge Ram 2500 4WD
Rancho 2001 Dodge Ram - 2500, 4WD, with 8800 GVW, with dual shocks, without snow plow package - RS5000 Shocks Logo
395 people viewed this question
Top Rancho Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Rancho Winter Sport Expert? Answer questions, earn points and help others
