Question about 3Com NBX® V3000 (3C10600BUS)
Reset password serial port
I cannot connect using serial console port (no signal / data out of serial console port). I don't have IP address of the DS4100B. I don't have its password... How can I reset it to factory default?
I am assuming you will still need console connection to do a password recovery.. however, here is the link to one password recovery doc that may help.
May 10, 2016 | EMC DS-4100B 32 Port 4Gb SAN Switch
Default password
The default password is blank (i.e., leave the password field blank).
Nov 18, 2013 | NetGear ProSafe GSM7248 48-Port Gigabit...
Cannot log into the SMC8024l2 switch via ethernet or console and after resetting to factory defaults still cannot ping the device at the default IP Address or the IP address it was set up on.
Looks to me like they never implemented the serial port. The used unit I just obtained has no signal on the serial console pins and no SMC documentation beyond plugging it in appears to exist. Likewise with TELNET access.
However you can reset the switch to factory defaults with the following procedure from a pop-up window off the login page. It worked for me.
If you have forgotten the administration password you can return the Switch to its factory default state by doing the following:
1) Remove the power cord from the back of the Switch.
2) Remove all cables from the front-panel ports.
3) Connect port 1 to port 2, on the front panel, using a standard network cable.
4) Reconnect the power cord to the rear of the Switch.
5) Wait at least 40 seconds before disconnecting port 1 from port 2.
After completing this procedure, the password will be 'smcadmin' and the network address will be returned to the default; 192.168.2.10/24.
Apr 02, 2011 | SMC EZ Switch SMC-8024L2 24-Port Gigabit
Can you tell me how to reset the bios password and figner print biometric device on a IBM X60 p/n 1702-3qu. I received these units off lease and need to reset both in order to wipe the hard drives and...
FOR IBM/LENOVO PASSWORD
Hello sir read these instruction. Solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. you need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..you need to made serial port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html Thanks
Nov 05, 2010 | IBM ThinkPad X60 Tablet PC
My IBM r 40 e laptop password not remember right now pleas help me how to recovery or reset
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to made serial port or printer port and there is software for it ...
Oct 13, 2010 | IBM ThinkPad R40 2722 Notebook
Voice Message
Wow. If your system is missing programming, the messages can get dropped into the General Delivery Mailbox (998). There are 2 passwords that are an absolute (well 3) nust to have, one for 998, 999 and the serial port master password. One will let you reset the other two, but the installer password on the serial port is not easily reset.
Carl
May 20, 2010 | Panasonic KX-T7630 Corded Phone
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
3Com NBX® V3000 (3C10600BUS) Logo
61 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
