Question about Android Apps
Authentication problem. I get the error saying authentication problem after authenticating for a long time. I tried elsewhere and it worked fine from a Telkom modem.
sandrew
  • 2961 Answers
SOURCE: Unable to apply any authentication for the Wireless
there should'nt be a problem setting WEP security or an other unless there is a firmware problem, as you simply select security, then the method e.g. WEP, select hex, then open system amd type manually your values for a chosen key number from 1 to 4.
Posted on Jul 27, 2007
bpcs
  • 112 Answers
Suggest resetting to factory defaults, then see if your can make changes to the authentication's. If not go the website of device and access help and support. BPCS
Posted on Dec 14, 2007
  • 34 Answers
SOURCE: authentication timeout
Try resetting the configuration of the router by holding the reset on the back for about 10 seconds, then reprogram the authentication settings.
Please rate this helpful if it was!
Posted on Jul 03, 2009
johnwmaustin
  • 222 Answers
SOURCE: authentication problem
Please clarify the d-link model number.
In setting up the phone and connection, you need to know a passphrase that was set up for the router. If you get that wrong, you have an authentication problem.
Posted on Sep 30, 2012
Geekman
  • 32281 Answers
SOURCE: Netgear G54 Wireless Router says authentication failed
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Dec 01, 2012
WI FI AUTHENTICATION ERROR ON ANDROID TABLET
Double check your login credentials. Try checking the caps lock key when entering the password.
Dec 01, 2014 | Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Authentication stage error
I am currently using hwk update client v 2.2.0.0 and I am getting Authentication stage error: Error: Server returned unrecognized reply.
Aug 19, 2012 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
HWK UPDATE
Originally Posted by MIRYALA SRINIVAS viewpost.gifhwk Update server has crashed,ODIA TEAM is working to fix the issue ASAP.
So dont update your box.
We inform you when server is working fine
Br.
Vijendra Saini.
dear sir,
i have format my pc then i need to install what should i do????????
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/8/2009 8:19:09 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 71327
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-7ACEA977416000C9
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Jul 25, 2012 | Computers & Internet
I get sending error 0x800ccc80 when trying to send messages...But all messages are send once or twice a day at random times...otherwise they sit in the outbox
Outlook 2007 is stricter than 2003 about SMTP authentication. It could be the case that 2003 tried automatically to connect without authentication when authentication failed, while 2007 throws an error.
Please verify the settings for authentication in your account, and uncheck the box “My outgoing server (SMTP) requires authentication", on the "Outgoing Server" tab.
Mar 18, 2010 | Microsoft Office Professional 2007 Full...
Microsoft says my os is not an authentic version but it is
Sometimes Windows asks for you CD as a security measure if your security has been used too many times.
You could run into some problems with updates unless this is corrected.
Jun 11, 2008 | Microsoft Windows XP Professional for PC
User access
what version of vista are you using, this is a very important piece of information, vista home flavors are not very network friendly,I recommend that you keep using XP until a few service packs are out for vista. If your using ultimate then something else would be wrong, possibly a setting on the vista box, Im not real sure how vista's authentication works but if they changed it enough then it might require a compatiblity mode or something in order to authenticate with 2000/xp, but then again i could be wrong and vista might authenticate exactly the same way as 2000/xp, try setting an xp box up as a server and see if the vista box can authenticate with it, if so then maybe 2000 is the problem, sorry i couldnt give an actual solution but im still new to vista myself and dont have any pc's that will run it, my good computers are all macs.
Apr 15, 2007 | Sony StorStation FSV-E1 80 GB Network Hard...
Android Apps Logo
27 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
