Question about Samsung Washing Machines
Samsung WA456DRHDWR/AA not draining - Samsung Washing Machines
2 Suggested Answers
t0ny_pars0ns
  • 4654 Answers
SOURCE: My Samsung washer model WA456DRHDWR/AA doesn't have any power. Need help troubleshooting.
Right place - well done.
Posted on Sep 11, 2017
Hey Cindy,
First, makes sure all the breakers have been reset and do not trip when you try to use the washer.. if the breaker trips each time you try to use the washer, then you need to cal a qualified repairman..If the breaker is good and stays on, make sure its plugged in correctly..if its plugged in and you have power at the plug..( are you mechanically inclined?).. if not call the Qualified repairman)..there are several things that will cause it not to work,,
Samsung WA456DRHDWR AA User Manual Check These Solutions If Your Washer...
http://www.appliancepartspros.com/repair-help/samsung-washer-wa456drhdwr-aa-0001-repair
check this out..
Samsung Recalls Top Load Washing Machines Due to Risk of Impact Injuries
Sep 11, 2017 | Samsung Washing Machines
Error code BE1 comes up at spin time & it stops. Common cause?
8e1 Front mems sensor error locates on main board check at main board fir loose harness. Probably a bad sensor or harness get both the sensor itself is under too near front right
Apr 09, 2016 | Samsung WA456DRHDWR: 4.5 cu. ft. King-Size...
Model wa40pjhdwr/aa. What causes the pump to continue running?
When the pump keeps running, you have a 'slow drain problem'. The machine knows it should empty in a certain amount of time. If it doesn't it runs the pump all the time. You can usually reset it by just unplugging it and counting to 10 before reconnecting.
It is usually caused by blockages in the filter or in the pump itself.
http://landersappliance.com/Blog/ArtMID/1641/ArticleID/43/Samsung-Washer-Service-Problem---slow-draining
and this video.
How to Diagnose Washing Machine Drain and Pump Problems
Feb 07, 2016 | Samsung Washing Machines
My WA456DRHDWR/AA Samsung Washing machine is making a grinding sound, like a belt is messed up. How do I diagnose the problem with no error codes?
open it up and watch while running .washers do not normally have belts would bet the bearings are going the trip
May 02, 2015 | Samsung Washing Machines
My drum has come loose from the bottom where the agitor is how do I get it apart so I can center it again?
I would guess that the bearing is loose or bad.If you lay it on its side you should be able to see whats wrong
Oct 05, 2014 | Samsung High-efficiency Top Load Washer...
I have a Samsung WA456DRHDWR. The drain pump went bad. I wasn't around so I don't know what happen but when I found it the pump had busted out of its' plastic mounting bracket and the 2 wires were dis
2 possible problems:
1. there is a tiny switch in the lower metal base of the machine hit it it might be stuck.
2. you have a problem with an electronic component in the main pcb called triac. this part is acting as a switch you need an electronic repairer to change it
Mar 24, 2014 | Samsung WA456DRHDWR 4.5 cu. ft....
Samsung GT-e2152 Display white problem solution
Samsung E2152 display thik hai par graphics nahi aa raha hai. display white aa raha hai
Jan 23, 2012 | Samsung Cell Phones
Washing Machines Logo
19 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
