Question about Boating
Engine won't run unless primer bulb is being pumped
At idle it runs fine but once the throttle is advanced it runs for about less than a minute it starts spitten then dies unless the someone is pumping the primer bulb. when someone is pumping the primer bulb while running it is fine upon advancing throttle.
  • ibcdac Jun 20, 2009
    Thank you for all your suggestions it was as simple as replacing a 5 year old priming bulb with a new one. Thank you all again
  • 3 Answers
I have the same problem and may have a solution. I looked at the primer pump and it was cracked letting air into the system. When I pumped it my finger was over the crack and it worked fine. When I stopped the crack was able to **** air again. Take a look.
Posted on Jun 20, 2009
    Problem Solver:
  • 5 Answers
Seems like a fuel pressure problem, either sucking in air at one of the fuel connections causing it to loose pressure or the fuel pump is faulty on your motor.
My prime bulb looses pressure and first start is hard. I have to remove fuel line from filter and cover with thumb prime re install then first start takes time.
Does the engine run fine after it starts? Most common problem with primer bulb losing prime is an air leak in the fuel line or primer bulb. Air leaks don't always leak fuel. If there is an air leak between the primer bulb and gas tank there is no pressure, only vacuum. If it is not a major leak it might not leak without pressure but it will allow air to enter the fuel line. If it is a very minor air leak it could allow air to replace the liquid in the fuel line over time, but so little air once it is primer again that the fuel pump can over come it with volume of fuel.
Primer bulbs do not stay firm, as they are when initially pumped up, after the engine is running. There are check valves in the primer bulb that hold pressure in the primer bulb and throughout the fuel line to the engine. Once the engine starts the fuel pump creates vacuum drawing fuel into the engine diminishing this pressure and releasing the check valves. At this point the primer bulb is just another segment of fuel hose allowing fuel to pass through it as the fuel pump demands. The primer bulb functions much better when the outlet side is higher than the inlet side. This position makes it easier for the check valves in the primer bulb to seat and release as needed. If the primer bulb is functioning properly and is positioned with the outlet side higher than the inlet it should not be necessary to cover the end of the fuel hose with your thumb to get it to prime.
If the engine is hard to start after being fully primed there could be a problem with the fuel system on the engine. Some engines are hard to prime once air has entered the system, especially fuel injected models.
Dec 19, 2014 | Boating
1959 35HP BIG TWIN WILL RUN SHORT TIME AT HAFE TROTEL THEN DIE
I need more info. Two hose fuel line? If single hose with primer bulb, can you keep it running by pumping primer bulb? Picture would help. Will it idle for longer? Will it go over half throttle?
Jun 25, 2014 | Clymer EvinrudeJohnson Outboard Shop...
Tecumseh starts won't idle unless you hold in the choke bulb
If you mean your having to pump the primer bulb to keep it running. Then the main jet is plugged.
1. Take jet(bowl nut) off the bottom of the carb
2. spray carb cleaner through all holes. (up to 4)
3. find a hemming pin and break of the sharp tip, run that through all small holes there may be one hidden in the threads.
4. repeat step 2. and dry with a shot of air( air dusting cans are ok).
These steps are for emissionized carbs( no mixture screws )
Oct 28, 2012 | Ultimate Sound Cyclone Rake Commercial Pro...
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
I have a Husky 435 model that is less than 2 years old and as cut only about a cord and a half of lumber . The saw runs fine when it is running the problem is getting it started in the first place . I...
It should start easily, start with fresh fuel/oil, pump the primer as many times as it takes to 3/4 fill the bulb, pull the choke fully out, crank the engine until it fires once, push the choke fully in and crank again until it fires up, after re fueling a warm engine, pump the primer again until it 3/4 fills the bulb,before cranking the engine pull the choke fully out and in again( this will engage the part throttle ) then crank the engine until it fires up.
May 15, 2011 | Garden
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
How to stART HOMELITE 18 INCH TIMBERLINE
Make sure you have fresh fuel mix in the tank. Pump the primer bulb about 6 times or less until the bulb draws fuel into it. This fills the carburetor with fuel. Close the choke and set the fast idle if the throttle trigger has a button near it--otherwise, operating the choke auto-sets the fast idle. Don't operate the throttle again until the engine is running. Turn on the ignition switch and pull the engine through smartly. It should start within several pulls. If nothing happens, then get back to us for some troubleshooting help. Hope this gets it running!
May 07, 2010 | Homelite ZR10926 16 Chain Saw
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Nov 01, 2009 | Toro Lawn Mower With Toro Power Tools
How do I adjustment the carb on an almost brand new weed trimmer?
The H is for high rpm (Main mixture) and the L is for Low rpm (Idle Mixture). First turn in both screws all the way in and then turn them both out 1 and a half turns. Pump the primer bulb if the equipment has one. Start the engine, once it is idling, turn the L (Idle Mixture) screw out (counterclockwise) from the preliminary setting until the engine speed decreases (rich). Note the position of the needle. Now turn the adjusting needle in (clockwise). The engine speed may increase, then it will decrease as the needle is turned in (lean). Note the position of the needle. Set the adjusting needle midway between the rich and lean settings as in the picture below. Don't touch the throttle during this procedure. Once you have found the best idle speed for the engine then you need to adjust the high rpm. This process is the same as with the idle rpm process but you need the to hold the throttle wide open while you are adjusting the H (Main Mixture) needle on the carburetor.
May 03, 2009 | Poulan Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Boating Logo
643 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
