Question about OKI C3400n Laser Printer
My black drum went bad quickly on my OKI c3530
My black drum didn't last long I didn't use printer that much
4 Suggested Answers
SOURCE: Black Laser Drum
I just end of ordering it and it should be here first thing this morning. Thank you.
Posted on Mar 20, 2009
  • 73 Answers
SOURCE: How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Posted on Oct 07, 2009
Testimonial: "Great fast response."
  • 81 Answers
SOURCE: need vista drivers for c3530 Okim es
Vista driver plus two more options
http://www.oki.co.uk/support/printer/printer-drivers/results.aspx?prodid=tcm:122-4377-16&search=1&OSId=Windows%20Vista&languageId=&type=%7cDrivers
Posted on Oct 15, 2009
Can i reset the drum life on an oki c3400?
On Oki C3200, there are only 2 terminals on the RH end of the drum -- those are the two you need.
I had trouble getting the wire tucked under the terminals on the drum. What I did that worked was just hook the wires to the spring contacts on the printer frame. Put a piece of black tape over the metal frame just to make sure no short between the frame and the wire. I also found a piece of black tape to retain and keep some tension on the wires worked well.
Analog VOM worked just as advertised -- thanks so much for a quick, easy, no-cost drum reset solution.
Photo attached.
Apr 14, 2011 | OKI C3400n Laser Printer
I have an oki c3530 and it is making a terrible grinding noise, any ideas?
One of the drums needs to be replaced. Systematically remove one at a time until the grinding noise no longer happens, then replace that drum.
Jan 26, 2010 | OKI C3530N Color MFP Printer
Oct 07, 2009 | OKI C3400n Laser Printer
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
Black Laser Drum
Mar 19, 2009 | OKI C5500n Printer
OKI C3530N Multifunction Printer
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
Symptom:
Cause:
Resolution:
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
OKI C3400n Laser Printer Logo
22 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
