Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
How much oil does a 139cc hold - Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
Overfill oil
Sounds like the engine is tired. Blue smoke is oil burning. Hard starting is oil on the spark plugs and/or low compression. This also can be due to someone adding too much oil.
Sometimes, the carburetor Needle valve hangs u pa bit and the Crank case oil gets mixed with gas so now the oil level is high. Too much oil in a motor is bad too, that would cause theblue smoke too.
Jul 20, 2013 | Yard Machines 11A08MB006 22Inch 139cc MTD...
Mtd 139cc ohv engine will start with primer, but stalls within two or three seconds
Ensure oil is full. Engine has a low oil cutoff. 30w oil. Replace carb only about $27.
Jul 11, 2013 | Mtd Garden
I HAVE OIL BLOW BY GETTING IN THE CARB FROM THE HOSE COMEING OUT OF THE MOTOR. IS THERE A PCV VALVE
hi
no pcv but make sure your air filter is not plugged up, make sure you didnt overfill the engine with oil you must remove the oil if overfilled if these are not any help you need rings or a new replacement better buying a new mower for that kind of repair trade it in
Joe
Sep 11, 2012 | Yard Machines 11A08MB006 22Inch 139cc MTD...
What type of oil do I use in my 6HP lawnmower?
Straight 30 weight oil is best, but a 10-30 will also work...
heatman101
Jul 17, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
It just quit running...sounds like it's trying to start...It has gas and oil and the filer is clean....
Check for spark, try pulling the wire and hold it near the engine while trying to start it, look for a spark to jump. If no spark replace the wire or the ignition coil. If you get spark try replacing the spark plug. if you get spark you should also pull the spark plug and see if the end of the plug looks wet if its not wet you aren't getting fuel and I can make some other recommendations.
Jun 08, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Yard macine model 139cc will not start. Has gas and oil... where is the spark plug located on the lawn mower? I would like to replace it.
The spark plug is at the end of the thick black wire in the middle of the front of the engine or looking at the mower from the front, it is to the left of center. Make sure you set the spark plug gap before installing it new. The gap is probably around .030". They have tools for doing this at the auto parts store. Sometimes and older plug can be cleaned with a stiff wire brush and some solvent and gapped properly and continue to work well.
May 28, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Yard machine 139cc ohv. wont turn over. cleaned carb and bowl. bowl gets gas but gas wont get into carb . think poss vacuum problem
Clean the brass bolt very well that holds the bowl on the carb. Pay very close attention as their are some very small holes in the smooth part of the bolt near the top, as well as the bottom. Use NO metal objects to clean this bolt.It is the main jet of the carburetor also. Once cleaned properly, your fuel flow into carburetor and engine should be restored.
May 24, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Morrison 460 what type of fuel?
you just need mixed fuel.
do you need to mix fuel and special oil . for sale on store.
Jan 26, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Does anyone know whether these Yard Machines lawnmowers take straight gasoline or mix? I cant find an onwers manual online to clarify it. To be clear I seem to have a bit of an oddball machine;...
Straight gas. Look around, and you will see where to fill the engine with regular sae 30 oil, and on lawnmowers, if you have a place to fill it with oil, you don't mix oil with the gas.
May 18, 2010 | Yard Machines 11A08MB006 22Inch 139cc MTD...
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
69 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
