Yamaha 5450 shuts off as soon as i turn it on stays for about 2-3 secs then turns off? any ideas
3 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Yamaha RX-V793, Turn it on, 2 sec later turns off
Hello, welcome to Fixya!
Your receiver is having a power fault because it is not switching on. The receiver might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the receiver.
If plugging into another power outlet doesn't power it on then it confirms that the receiver is having a power fault.
When electric current comes from the power outlet into the receiver, it goes straight into the power supply board which then circulates the current into the unit. So if the receiver doesn't power on, the first thing is to make sure there is power entering into the receiver.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Good luck.
Posted on Jan 11, 2012
  • 6771 Answers
SOURCE: yamaha rx-v371 shuts off 2 secs after turning on
Return unit to place of purchase, this is clearly a manufacture defect. The warranty will cover full replacement, do not allow them to attempt repair on the current item because you will be back and forth until warranty runs out.
Posted on Apr 02, 2012
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
My Cyberpower 550VA keeps turning off. I can turn it on, and it will stay on for maybe 2 seconds, and then it turns off again. Any solution?
your ups cannot get enough power from the outletreplace the battery of your ups 12volt 7ampere reset the small breaker. when it still turning off test the continuity of the small breaker and the cord to plug use a multitester.
Aug 25, 2011 | CyberPower 550VA 330W UPS Green S System
My new Acer Aspire 5734z shutdown the day before yesterday. It sometimes will let me stay a few secs in safemode but then shuts down again. I dont understand why and im not really good at fixing computers...
Please try fixing it by running LKGC.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Dec 28, 2010 | Acer Aspire 5735 Notebook
Yamaha R6 2003 (first of the fuel injection) bike idles but as soon as you go to turn the throttle revs go to 6000 and stay there for up to 40 seconds after the throttle has been shut off (butterflies are...
Hi, Jack and the usual suspects are:
1. Faulty TPS-IAC-MAP-ETS-ISP sensor and or o-ring.
2. Throttle plate stop shifted.
3. Throttle plate shaft cracked-broken-faulty o-rings.
4. Throttle body to cylinder head seals/gaskets leaking.
5. Throttle cables improperly adjusted-damaged-kinked etc.
6. Vacuum lines cracked or broken or missing.
7. Faulty fuel tuner or out of adjustment.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r6messagenet.com/forums/r6-maintenance-technical/158635-2003-r6-idle-problem.html
Help high idle
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 13, 2010 | 2003 Yamaha YZF-R6
My TV turns off. As soon as I turn it back on it
try the lamp door switch in the back of the TV, door is held on by 1 screw, after door is open there is a blue switch by the slide that protects the lamp. push the switch down and up a couple of times then put cover back on and see if tv stays on. this was my problem with this exact tv.
Dec 17, 2009 | Samsung HL-S5086W 50" HDTV
When go to turn on laptop wont stay on lights up like it is going to stay on but shuts down as soon as you lift off your finger
remove the battery and ac adapter and hold the power button for 10 sec and remove all the external devices and connect the battery and ac adapter and try if no try diffrent diffrent ac adapter or wall unit
Aug 17, 2009 | HP Computers & Internet
Yamaha rx-v663 receiver worked only one week. next time i went to play stereo as soon as i turned it on it only stayed on about 2 seconds then shut down. i am able to try three times with same results...
The click is the autoprotection relay that should be allowing the amp to stay up. Try this... turn the speakers off if you can, or disconnect them then try again. Safety shutdowns are usually either heat or short circuits in the output stages. It doesn't stay up long enough to get hot so...
If it stays up withou the speakers on then the problems is probably external and easy to isolate.
Let me know.
Apr 03, 2009 | Yamaha RX-V663 Receiver
Rx-V2400 Shut Down
Hi Seems like you have a shorted output channel, remove all your speaker connections and try again, if the problem persist, good chances are that you need to replace a couple of power transistors, let me know if you need more help, I've fixed some Yamaha amplifiers with this problem Good Luck Miguel
Oct 06, 2007 | Yamaha RX-V2400 Receiver
76 people viewed this question
 Grubhead
Grubhead
