Hi, have a simpson esprit 6.5 that wont spin. Does the whole cycle but wont spin at the end. Can anyone assist. Cheers
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Hi my simpson esprit 550 has suddenly stopped spinning,does everything else fine,any suggestions wod b much appreciated,thanku
Has it pumped out? It wont spin if still full of water. Check for blockages etc in hoses and the pump. If its pumping out, there could be a problem with the brake release or it may be the lid switch. It wont spin if the machine thinks the lid is open. Older 550,s had a switch that was operated by a lug that stuck out of the back of the lid, newer ones have a magnetic switch under the top of the machine.
May 19, 2015 | Simpson Washing Machines
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
My washing machine spins but doesnt complete the spin cycle
does it drain all the water out/ If not then check your pump filter.
Oct 04, 2014 | Simpson Esprit 750 Top Load 7.5kg
Simpson washing machine will not fill
faulty control board or timer
Nov 19, 2017 | Washing Machines
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Main power flicks off when starting my simpson esprit 750 washing machine
Hi just read your posting,Now there are two types of Simp esprit,Is yours a top loader or a front loader? Does the machine trip the fuse when you select the spin cycle or only when it starts to fill?Have you tried putting it on a spin cycle?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Aug 28, 2010 | Washing Machines
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Jul 06, 2009 | Washing Machines
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
