FURSYS Cubicles Find installation Manual
I am in desperate need of instructions on how to assemble Haworth Cubicles that I bought used online.
Oh boy! Do you have lots of fun ahead of you! I did the same thing. I bought Haworth cubicles on line and what I saw vs what they dropped off were two different things. I ended up with pieces to three different sets and none were complete. We had no more money in the budget to buy more soe we had to make what we had work. I dont know the name of the system (style name) that you are trying to build or I could be more specific - here is a link with wall installation schematics and parts detail. That should help you start your project.
Here it is:
http://www.oodlesofpartsplus.com/haworth_parts.htm#haworthparts
Aug 15, 2011 | Office Equipment & Supplies
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Its not producing ice anymore.
Sep 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice cubes form a mass that do not dispense
Sep 11, 2009 | Kenmore Refrigerators
External Nortel Modem won't connect
DSL uses one wire pair since it runs off a POTS line (plain old telephone service).
The Nortel modems are very old - they were some of the first DSL systems that came out almost 15 years ago. They were designed to work with their own proprietary Nortel back-end (DSLAM) equipment. Since they use proprietary and now way outdated transmission protocols, they will not work with modern DSL connections since they do not support the standard DSL protocols. Unless there was somekind of firmware upgrade I wasn't aware of, its pretty much junk.
Nortel went bankrupt a couple of years ago. I used to work for them and some of the guys who designed their DSL modems worked a few cubicles away from me. I had a couple of them in the early days (we got free DSL as beta testers back in the mid-90's) - the modems are useless now, but I found the power supply worked well with my cordless drill charger.
Sep. 2010, Ottawa
Sep 10, 2009 | Computers & Internet
I have a magic chef side by side and my freezer fan wont stop run
1) Either the ice cubicles are not filling with water, or 2) The ice is not dumping into the bin after it freezes.
To check for #1, you should be able to look into the ice cubicles to see if they're filled with water (or ice). If they are, go to #2. If not, you've probably got a defective water valve.
If the cubicles are full of ice or water, but don't dump out, the most likely culprit is the cubicle heater, which slightly heats the walls of the cubicles so that the ice can be more easily ejected into the bin. Unless you're VERY mechanically inclined, this is a job best left for an appliance repairman.,
thank u
rate me
Jul 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have a kenmore 106.53593200 fridge the ice maker not making ice but i can feel its running
As long as your freezer will freeze water, your ice maker will make ice. All the ice maker does is supply the water, then dump the ice after it freezes.
So, that narrows it down to: 1) Either the ice cubicles are not filling with water, or 2) The ice is not dumping into the bin after it freezes.
Jun 27, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
APC UPS issues
If its really a noise? neutral and ground of your utility power (building transformer) should be bonded
Apr 14, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Office cubicle assembly
Can you post a picture? We may be able to help if we see which model you have. Instructions manual will hard if not impossible to come by.
OC Furniture Assembly
www.ocfurnitureassembly.com
Dec 07, 2008 | Computers & Internet
Setting the volume
There is no fix to this problem. I emailed GBX, who makes the same stereo (same model number) and they said it is a factory setting that can't be overridden or changed. I bought mine for work and my office is made up of open cubicles - I'll be returning it tomorrow.
Jan 07, 2008 | Durabrand HT-3915 System
20 people viewed this question
jasbo
jasbo
