Question about Bosch HBL 442 / HBL 446 Electric Single Oven
Bosch helpline How do I get the child lock off I cannot use
Bosch integrated oven has a c11 error code. What does this mean please.
Sounds Like child lock activated check owner manual or send us a model # glad to help more
Jan 31, 2017 | Bosch Ovens
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
CHILDLOCK WONT SWITCH OFF ON BOSCH OVEN
Aug 05, 2014 | Bosch Ovens
Child lock
I can't find any mention of a child lock in the manual:
https://drive.google.com/open?id=1Ja2o9qZPTI809jaklqZFyIuHtspje_cNC0egEcUE6cf0TJ0Sc888U_0Q3s0OrYgE9iepD1Oq3feZZNKX
It seems to only lock when it is in self-cleaning mode @ ~320 degrees centigrade
Feb 20, 2014 | Candy FP855 Electric Single Oven
Oven randomly rises to very hot temperatures
The oven controls its temperature by using a thermostat sensor. In some ovens this is visible as a small bulb or tube on the inside about the size of a childs finger. Can you see it, has it been damaged? If on the bosch its not visible its still worth buying a new thermostat and dismantling the oven to fit the new one.
Dec 15, 2013 | Bosch Ovens
Turn off child lock
Can you identify the model of the oven you need help with or anything like that? Not all child locks on ovens are configured to function or be utilized the same way.
Sep 22, 2013 | Ovens
How do I remove the child lock message on my Panasonic Inverter Microwave?
Press {Stop/reset} button 3 times to unlock the unit. Or un-plug it for a little while. To put the unit into child lock press the start button 3 times.
Aug 20, 2011 | Ovens
I can't unlock touchscreen panel
This is an safety features that prevents unwanted oven operation by children.
To set child lock...
Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
Then you can cancel the CHILD LOCK according the below procedure...
Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
Hope helped with this. Good luck.
Nov 04, 2009 | GE Ovens
Bosch HBL 442 / HBL 446 Electric Single Oven Logo
16 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
