Question about Precor Exercise & Fitness
Download software c954i - Precor Exercise & Fitness
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
To update the software on Precor products, you will need Precor's proprietary software on a laptop and several special adapters. Hire someone certified.
Posted on Jan 18, 2015
I have a C954i treadmill and both down arrows (incline and speed) stopped working at the same time. I own and operate a 24 hour gym and it a favorite.
There is a small control board attached under the directional pad. It sounds like it has come loose from the housing. You can get to it one of two ways. You can unscrew all of the back cover screws on the console and then pop the front overlay off using the tabs under the back cover or you can get your fingernails under the edge of the plastic on the front display and pop it off that way. Precor would not approve of doing it that way but it won't hurt the display. The small D-pad pca can be easily snapped back into place. If you get to the pca and its still secured in the D-pad, the control board itself may be bad.
Sep 16, 2014 | Precor C954i Commercial Treadmill
Why does my precor C954i keep shutting off
It must have been crossing its excess weight limit..
Jun 26, 2014 | Precor C954i Commercial Treadmill
Precor c954i error 16
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Sep 08, 2012 | Precor C954i Commercial Treadmill
My precor c954i displays message STOP KEY and will not run? How come?
1) adjust the reed swithc, clean , and tigh the wire connectors very well
2) run the software calibration for diagnostic and troubleshooting.
God bless you
Jun 19, 2012 | Precor C954i Commercial Treadmill
What os the meaning error 42, 49, 45 on the treadmill C954?
This erron had implies with the elevation motor.
Please RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you
Jun 08, 2012 | Precor C954i Commercial Treadmill
What is the mening error 42,45,40?
this mean incorrect position from elevation motor.
Please RUN the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Precor c954i can speed up but cant reduce the speed
Dear Sir:
Please adjust the speed sensor see the diagram attached.
After RUN the software calibration for easy diagnostic and troubleshooting
See my personal TIPS FOR Help.
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Mar 30, 2012 | Precor C954i Commercial Treadmill
Why does my preco treadmill keep saying calibrating lift?
1) Under cover the main motor or in your instruction manual, there are section for calibration.
2) I recommend that you do it, in accordance with the instructions.
3) If you do not have owner manual go to website: www. precor.com
go to customer service, then parts& manual give your model, etc and download for free. you can go too for free www. iconservice.com with the same procedure.
sincerely.
Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA.
Dec 04, 2011 | Precor C954i Commercial Treadmill
What does error 29 mean on a precor C954i?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29
Apr 06, 2011 | Precor C954i Commercial Treadmill
Exercise & Fitness Logo
61 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
