Hitachi UltraVision CineForm 55VG825 55 in. HDTV Television
Problem for Hitachi UltraVision CineForm 55VG825 55 in. HDTV...
Blue shadow
By rvarner1992 on Jun 20, 2009
I have a blu shadow around the top part on the screen when the captioning is on top there is a blue like ghost arount the writing and sometimes other tings also
Best Solution
posted on Jun 20, 2009
Very Helpful)
Ecollier2012
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 93%, 579 votes
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jul 17, 2009
Somewhat Helpful)
kysted
Rank: Apprentice
Rating: 75%, 1 votes
This isn't so much a solution as it is a question ... what if I don't have the original remote control from this TV? How else can I access control of the convergence settings?
Was this helpful?
Yes
No
Popular Solutions for Hitachi UltraVision CineForm
Questions and Unsolved Problems for Hitachi UltraVision CineForm
Do you recommend Hitachi UltraVision CineForm 55VG825 55 in. HDTV Television?
Answer
Answer
the tv is 5 yrs old and the picture is not in focus. this appears to be mainly at the bottom of the... (More)
Answer
straight lines on the bottom of the screen in Hitachi ultravision tv that is probably 8-10 years... (More)
Answer
my son hit the power on the surge protector the tv is plugged into. when I turned on the surge... (More)
Answer
Audio on Hitachi ultravision 65 inch has started to go in and out. Audio will go real low and after... (More)
Answer
yellow tint on the left side of the screen, plus thier is a faint double picture on that side
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
