Question about GE GTUP270EMWW Washer
Wash and spin light blinking - GE GTUP270EMWW Washer
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here---> https://panasonic.encompass.com/shop/research_new/HAI/sm/HLP21N.pdf
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
LG top loading washing machine spin not work n
Try test your lid switch. If the switch is inoperative, the machine will not spin or drain when it gets to that cycle on the timer
Sep 25, 2014 | Washing Machines
Spin light is blinking on my crosley washer
check belt is not Brocken filter is cleaned also can be the motor not turning check brushes or that the motor is not burned
Aug 13, 2014 | Crosley caw9244xq 3.4 cubic foot white...
I am getting an error it is as follows: finished, spin, and wash lights blinking plus 3 beeps. What does this mean?
Try restarting it, make sure the load isnt to heavy, if that does not help, call a local repair man.
Nov 06, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Fills up with water, wont wash, drum motors works
Sounds as if this computer is trying to display an error code. If switching cycles manually makes it work, then it is most likely a bad circuit board. Try doing a google search for "Kenmore washer lights blinking" or something to that effect.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
Lg washing machine f1068 ldp while washing stopped on spin and all spin lights are blinking
this could be the pump what you need to do is make sure the machine is off and down on the right hand side bottom of the machine there is a round cap clip it down then you should be looking at the pump turn slowly make sure you have a towel down there could be loads or some water coming out DONT undo it quickly OK very slowly until all water is gone then you can pull it out after turning it to pull it out if its all clear then you could have a motor problem but do the pump first OK let me know if this work OK don't for get to put the pump screw back tight OK
Oct 12, 2012 | LG Washing Machines
Washer is Full of water and clothes but won't drain. The washer will not start in any cycle. Lights are on ( the start light is blinking). Tried unplugging but still will not start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
GE GTUP270EMWW Washer Logo
132 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
