Question about HP Vs17 17" LCD Flat Panel Monitor
Monitor Comes On then Goes Off After 2-3 Seconds
I have the exact same problem with my HP vs 17e and it does the same thing on other computers. The blue power light stays on but the screen goes black even after many tries and reboots. Please do not send me a subscription repair solution.
Any help would be nice
  • Henry Gardner Jun 20, 2009
    No no no. I refuse to pay $100.0 plus when I can buy a new monitor (already have) for $109.00
    What I need is a new backlight inverter which apparently sell lfor $20.00. Where can I get one? I am capable of replacing it myself for free!
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
SOURCE: black screen
Hi
my problem was fixed by viziks from FixYa dated Sep 12
replaced 2 push pull transistors 2sc5707 in high voltage transformer circuit
Transformer used for backlight lamps
Both monitors now working THANKS VIZIKS
Posted on Oct 12, 2008
  • 7 Answers
SOURCE: HP vs19e Computer turns on Monitor stays Black. blue light blinks
Easy step-by-step tutorial for replacing the caps in this monitor can be found at the link below:
http://boredprojects.blogspot.com/2009/09/hpvs19e-monitor-fix.html
Posted on Sep 28, 2009
SOURCE: I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
Posted on Dec 09, 2009
  • 5 Answers
SOURCE: my hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Posted on Jan 13, 2010
My monitor comes on for 2 seconds and then goes off. If I turn it off then on again it does the same thing. when it comes on I can see my home page. I know the computer is owrking because I hear it when...
when monitors recieve no input the usually turn off or at least turn black.
it is possible that you have the monitor set to the wrong input, or that the cable is not connected correctly at the computer, sometimes there are multiple connections available, especially when there is both an on-board and an additional graphics driver.
if none of those things are the cause of the problem, there is a chance that the monitor is not receiving enough electricity, this can be very dangerous, try unplugging anything using the same wall socket or fuse and trying then.
Apr 15, 2011 | HP Vs17 17" LCD Flat Panel Monitor
I have a HP vs 17e monitor with built in speakers. After my hard diak was reformatted these have stopped working. Any way to get them working again?
Are the drivers installed?
Go to Device manager and make sure there is nothing with yellow question mark next to it.
If there is you are missing a driver.
Let me know how it goes.
Jan 28, 2011 | HP Computers & Internet
Monitor goes dark after about 2 seconds
I have the same monitor, its a power supply problem from the computer most likely. check the cable connections etc... I would get a service call from an authorized dealer near you ... about $120.00. Hope this helps:)
Jul 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor comes on then after 2 seconds screen goes black then if i turn it off again then repeat the process does the same thing
hi,
the power supply of the light tubes is not working well
you need to replace the capacitors of the power suply
the value of the capacitors are bethween 220/40V 470/40V normal theire are 2 pieces.
you will find this in the bak of your screen after removing the cover, its near the tube connectors located.
greetings
Feb 16, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
I have no power to my HP vs 17e. It appears that
This is a powerboard problem,look for bad caps(blowing up)
look at my profile to find a solution and the pictures for the HP version.
Jun 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Monitor comes on for 2 -3 seconds then goes off again
When you say "It comes on" do you mean that: A) The power light comes on B) the screen backlight comes on C) The above 2 happen and you get an OSD D) you get A+ the OSD comes on then you can only see it faintly E) Other please specify.
Jun 07, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP 1702 Monitor comes on but immediately goes off.
There are five capacitors on the power board which have dried out and need replacement. A reputable repair shop should be able to fix this for around $50.00 including labor.
Mar 23, 2009 | Computers & Internet
LCD monitor comes on for about 10 seconds then goes off
It sounds like the power supply board on the monitor may be faulty (that or the backlight).
You could test it on another computer to see if does the same thing (or another monitor on your computer).
If the same problem occurs on this LCD you'll either need to get it repaired under warranty, or pay for it to be repaired. Or just throw it out.
Dec 09, 2008 | HP w17e Monitor
My Sceptre X7 LCD computer monitor comes on at startup and goes black after about two seconds. I turn the monitor off and on again and the picture comes on foe about 2 seconds and then goes out again. The...
SORRY MONITORS R MONITORS THEY EITHER WORK OR THEY DON'T. WARRANTIES R THE BEST THINGS FOR MONITORS.HAVE U TRIED THE COMPUTER ON ANOTHER SYSTEM TO MAKE SURE YOUR VIDEO OUTPUT ON THE COMPUTER IS WORKING CORRECTLY
Aug 11, 2008 | Computers & Internet
HP Vs17 17" LCD Flat Panel Monitor Logo
396 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
