Question about Air Tools & Compressors
Starter feedback contact alarm at GA 160
What is the caused of " starter feedback contact alarm " of GA 160? what are the solutions to eliminate this alarm?
What is reason for starter feedback contact open and what is the solution for this in atlas copco ga110 compressor
so without having a meter on this my first idea is the motor starting contact relay saddle mounted contacts either have a wire loose, broken, or the contact itself has failed and not sending the feedback to the plc that the motor starter has in fact closed to start the motor, one way to trouble shoot this is to manually close the motor starter and ohm out that particular contact set to see if this shows it closed. do this with the power off as when you close this manually it will try to start the motor. ohi it before and after u manually close that starter relay.
Nov 14, 2017 | Air Tools & Compressors
Where to tap starter
You are only tapping a starter solenoid to see
if the internal contacts are burnt & preventing
the starter from getting any voltage or current
If you have eliminated the battery & cables &
have voltage at the starter solenoid with the key
turned to start ( need a helper & a volt meter,not
a test light) then remove the starter & have an auto
parts store test or replace it
You can also just install the solenoid,in which case
you take the old one apart ,to see what the problem
was & how it works. That is how you learn things
Sep 10, 2012 | 2003 Jeep Liberty
1997 Lincoln Continentalhorn won't stop honking
First, Have your Battery tested. The Alarm systems in Ford made Products are very sensitive to Voltage. There are 3 systems in the car which interrupt power, the Alarm system (horn honking) and the Battery saver and finally the starter interlock system.
The Alarm system will do several things to disable the car from starting. It will reduce the voltage to the starter to prevent the engine from turning over. Some will even kill the ignition system so that if the starter is jumped, the car still won't start.
The Battery saver will disconnect any system to prevent discharge below a minimum threshold. Unfortunately, when the Alternator is working extra hard to charge a really bad battery: it will disconnect the charging circuit because it reads the Draw going to the Alternator to produce the power as a parasitic drain. Even at 70mph I have seen the charging disconnected and the vehicle coast to a stop when the electric runs out.
The last system worth mentioning is the Starter interlock. Under the dash and at the top of the Brake pedal lever is a switch. When you press the brake pedal, the switch allows the starter to crank provided the shifter is not in D or R. Drivers feet routinely hit this switch and either move it or break it. When it breaks it can short and drain the battery.
As you mentioned a Random problem, the Brake switch can shake to create a random problem if it is loose or broken. Your rear brake lights can be affected.
With the horn honking, at least part of your problem is the Alarm system. You can have a bad ignition switch too, which reads the keychip to disable the alarm. Your keychip may be bad and setting off the Alarm.
I had a new Lincoln myself which set off the Alarm randomly. I actually slept inside the car one night so I could turn off the alarm in the Apartment complex parking lot. Did'nt know if it would start again if the battery was disconnected and then reconnected. The Battery was shorted with less than 1000 miles on the car. It was a factory defective battery less than 3 months old.
But your car has many years and miles on it so it was worth mentioning the wear items. I hope my solution is helpful.
Sep 07, 2012 | 1997 Lincoln Continental
2006 yamaha grizzly starter wont stop cranking
Possible solutions;
1. starter contacts sticking-take the switch apart and clean the contacts or repalce the swtich.
2. wire to starter button shorting/grounding-look for broken/shorting wire from the starter switch.
3. starter solenoid contacts welded together-replace the solenoid
Aug 21, 2012 | Motorcycles
My 1990 corolla wont start after I have driven it for a few hours
Some of the tests I can recommend for free require the car to be driven to Autozone, Advance, or Oreilys. You need to have the charging system and the battery checked. Then they can check the "draw" of the rebuilt starter for performance. Or have the starter removed and bench checked. It should have some type of warranty.
Now other problems can cause you to destroy a starter. One of them being a malfunctioning Alarm lockout. When the battery is low, a lockout may still reduce the voltage to the starter on purpose. This is a form of antitheft.
You need to explain to us if the engine was turning over before and if the engine tried to fire at all. Some heat related failures occur in the coil.
I hope my solution was helpful.
Jul 16, 2012 | 1990 Toyota Corolla
Can i use 10 gage wire rather than what, 12 gage, to connect altenator to starter?
Only if you really want to burn your vehicle to the ground. The alternator on your Saturn connects to the starter solenoid with a 12 Ga. Fusible Link.
Replacing that wire with anything but 12 Ga, Fusible Link wire is a one-way ticket to a fiery grave. Standard 12 Ga, wire should also NOT be used.
Jan 24, 2012 | 1999 Saturn SL
My alarm goes off while I am driving and also when car is off every now and then how can I fix this?
IF ITS THE FACTORY ALARM,ITS THE ANTI THEFT MODULE.THERE IS A BUTTON UNDER THE DASH THAT YOU HOLD DOWN WHILE TURNING THE KEY IF IT DOESNT START. SOMEONE HAS MOST LIKELY JUMPERED THE SWITCH SO IT WILL START AND DRIVE BUT THE MODULE HAS FAILED.ITS COMMON ON FORDS
Dec 16, 2011 | 2002 Ford Explorer
My car doesnt lock the door when its armed but opens when disarmed
one possible solution is check the wires connected to door lock and starter module , look at the starter diagram and trace the related wire, this wire need to be soldered again
Mar 01, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
2000 H.D. Sprotster; starter will not turn when you hit the start button, just get a clic. Battery is good and lights are on. Is this a starter problem or is there something else I should check.
Hi and welcome to FixYa,
Almost always, the click indicates that the starter relay is working or at least trying to.  Initial checks:
  • externally charge the battery and have it load tested (just to eliminate the remote possibility).  Necessary precaution if the bike is equipped with alarm/security devices;
  • bypass the starter relay by jumping the 2 big terminals on the nuts (not on the threaded portion);
  • expect a big spark;
  • the starter motor should spin;
  • if it does, then the starter relay contacts are pitted, burned or corroded and would require replacement;
  • if it will not, then a starter motor problem most likely the carbon brushes and/or commutator segments.
Postback results of tests.
Good luck and thank you for asking FixYa.
Aug 02, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Air Tools & Compressors Logo
107 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
